Pacific Alaska, California, Hawaii, Oregon and Washington
LT1 vs LS1
Old Mar 24, 2003 | 12:50 PM
silicuda's Avatar
LT1 vs LS1
What are the stock 1/4 mile times for LT1 vs LS1? (TRANS-AM)
Are both equally modifyable?
How much does an aftermarket procharger supercharger cost?
Old Mar 24, 2003 | 01:13 PM
Draco's Avatar
a stock LS1 will generaly run 13.1-13.5 depending on year. the newer LS1's are faster then the older ones.
a stock LT1 will generally run a 13.9-14.2 bone stock.
An LT1 will be cheaper to modify with basic bolt-ons, however a heads and cam LS1 will be faster then a heads and cam LT1. Also the stock LS1 motor is a wee bit stronger then a stock LT1 so you can throw a little more nitrous and boost at it.
Old Mar 24, 2003 | 02:34 PM
JD30thZ28's Avatar
Wink
Procharger D-1 with Twin Intercooler for the LT1 is $5300cdn
Procharger D-1 with Intercooler for LS1 $6600cdn
As stated, cheaper to build up an LT1 but the LS1 will be faster in most cases I my opinion the LS1 is much better but for now I'll keep a few of them in my rear view
Old Mar 24, 2003 | 07:21 PM
Camaro ChriSS's Avatar
The aftermarket definitely favours the LT1, IMO. And, technicially, for less money, you can get the LT1 to go faster (because you're starting with a lower priced car). If I just wanted to go fast and had a really limited budget, I'd be going LT1.
I went LS1 though (as my budget isn't so limited - only partially ) because I loved the styling of the newer SS (or TA) and the basics of the engine.
In my A4, my LS1 was hitting 12.96 on a good pass. On the dyno, with only very minor intake (all ordered through GM, so technically factory), I was hitting 314-322 rwhp (and a little more torque). And that was in an automatic. Some of the 6-speeds (01-02 that have the LS6 intake) are pullin 325-335 rwhp. That is a very high starting point.
But, it all comes down to styling preferences, budget, and ultimate goal.
Old Mar 25, 2003 | 01:59 AM
sleeperZragtop's Avatar
There both great cars...as of late working on Shawns and Craig..I found to be a lack of room...and the opti is bunk...you'll get better botom end from and LT1...but we have a bit of a stronger top end...so in the end pretty much equal
rideordie
Nov 5, 2019 04:52 PM
jayblev95
Track Kill Stories
Jan 15, 2015 07:48 AM
ddr698
Jan 9, 2015 10:05 AM
