Replacing C-Clip in Rear End
Old Mar 23, 2003 | 09:57 PM
C Man's Avatar
Having some squealing problems around right hand turns..... it seems the caliper is rubbing a little as the tires moves out.
Going to pull check the wheel and brakes but if it is the C-Clip... how hard is it to replace?
Old Mar 23, 2003 | 10:34 PM
cop01's Avatar
it takes no mechanical know how whatsoever. if you already had the cover off and it drained it may take you about 2 minutes if you have NO clue what your are doing.
Old Mar 23, 2003 | 10:38 PM
norcalstreet's Avatar
Very easy. Pull off cover, drain fluid, remove retaining screw from differential, pull retaining pin, go to each side of your car and push in the wheels. The axles will push in and the C-clip will fall out. Slip the new one in and reinstall everything in reverse order. Remember that when adding new rearend fluid you have to add the GM additive or it will continue to squeal.
Pretty easy.
Old Mar 24, 2003 | 08:20 AM
C Man's Avatar
Wow... and I was going to take it to a shop. If it's that easy, I'll be doing it this weekend.
Thanks guys for saving me a few bucks.
Chet1185
Feb 4, 2015 09:51 PM
jcamaro95lt1
Jan 24, 2015 08:21 AM
nodnarb481
Middle Atlantic
Jan 1, 2015 11:43 PM
Hurin
Dec 13, 2014 07:38 PM
