Asap!! Please Help Quick!!!!
Old Mar 23, 2003 | 05:36 PM
Sanger's Avatar
I was doing the 1.6 rocker install, and got to doing the first cylinder. It have it at TDC for piston #1. When removing the valve seal, the valve fell down to where i can see it, but i just can't pull it up. It's about 1/4 inch from the top of the valve guide in. I need to know what I can do to get this back up. Please anyone who knows, please reply quick!
Old Mar 23, 2003 | 05:54 PM
1994TransAm's Avatar
maybe a magnit?
one of those magnit sticks they sell at the zone?
Old Mar 23, 2003 | 05:58 PM
Ben383's Avatar
I'd first try a magnit , If that does not work you most likley will have to pull the head off . Goodluck
Old Mar 23, 2003 | 06:01 PM
Apparently you are not at #1 TDC. Use a telescoping magnetic pickup. You should already have one to retrieve your valve locks. If you don't you are going to need one anyway.
Old Mar 23, 2003 | 06:29 PM
Sanger's Avatar
Whew!!!! I got it fixed guys!! what a relief!! What I did was turn the motor clockwise and wha-la! It came up! It seems I had to have it at 4 o'clock or so position? Is that wrong for some reason?
Old Mar 23, 2003 | 06:54 PM
You got lucky. If the piston had been on the down stroke, you could have lost your valve into the cylinder. Also, depending on where it was sitting on the piston, it could have gotten caught and bent the valve. If your #1 is at TDC and the hub indicator is not at 12, then the hub is not indexed correctly to the crank.
Old Mar 23, 2003 | 07:37 PM
93Z286Speed's Avatar
if at TDC the valve will only fall in enough to where u can get it back easy enough... no?
Old Mar 23, 2003 | 08:10 PM
True.
IndyZman
Oct 22, 2015 02:17 PM
68camaroboltz
Oct 5, 2015 11:56 PM
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
NewsBot
Sep 14, 2015 09:20 AM
