Vorteh elbow
Old Mar 23, 2003 | 04:36 PM
scyzoryk's Avatar
Vorteh elbow
What does it do besides it looks nice?
Old Mar 23, 2003 | 04:39 PM
teke184's Avatar
doesn't allow you to use an airfoil without serious modification to the elbow, acts as a heat sink, gives you hassles with the IAT sensor...
and costs way too much...
how's that?
Old Mar 23, 2003 | 04:45 PM
scyzoryk's Avatar
**** I have air foil ....What about L1e elbow...Some people say that it flows better than stock...
Old Mar 23, 2003 | 04:53 PM
95TA8280's Avatar
The 1LE, more or less, only gets rid of the donkey shlong........
Old Mar 23, 2003 | 07:36 PM
taner's Avatar
From: Windsor, Canada: Home of the FASTEST LT1 & LS1 6 spds :)
Lightbulb
not only does the 1LE not have the bottom extension, but there is no added hole leading to the silencer! so it is a bit diferent.
Old Mar 24, 2003 | 06:25 AM
IDOXLR8's Avatar
Another option would be the new Trick Flow Elbow. I just got mine on SAtuday and it is a nice piece. It also does not have the divider going thru the middle of the elbow.
Old Mar 25, 2003 | 12:50 PM
taner's Avatar
does anyone make one without a divider? i have a mono blade and want all the air i can get, lol!
Old Mar 26, 2003 | 06:51 AM
KYWes's Avatar
I went with the Vortec cause it was a little cheaper. It mated just fine to my car. It was already tapped for the IAT sensor. You have to file down the sensor and then thread it but it wasn't too hard. I also had to drill a hole for my Optispark vent and tap that too but it wasn't hard either. The hardest thing for me was finding a size "R" drill and correct tap. It does have the divider but I'm pretty stock so I see it as a help. Here's a pic:
http://bellsouthpwp.net/K/Y/KYWes/pictures/elbow.jpg
I chose the non-polished and decided to paint it black.
Yes, I know, I need to clean the engine
Old Mar 26, 2003 | 10:37 AM
IDOXLR8's Avatar
The new Trick FLow Elbow does not have a divider.
Old Mar 26, 2003 | 11:16 AM
1msfyter's Avatar
No problems with mine, I use the SLP air foil,fits perfect.
I had to trim 1" off the elbow for the SLP cai. I relocated the IAT to the SLP cai(air hole for airpump)Finished it by powdercoating
to match.
www.bealer.org/bmrrad.jpg
Old Mar 26, 2003 | 11:29 AM
ShelbyZ28's Avatar
to match.
Looks good . Relocating the IAT to the CAI is a great idea. It cleans up the elbow alot and hides the IAT from sight. I was going to get the polished elbow but you got me thinking. Matching the elbow to the SLP CAI looks sweet! Thanks for the pics and ideas.
Bryan
Old Mar 26, 2003 | 11:52 AM
1msfyter's Avatar
A closer shot of the relocated IAT
http://www.bealer.org/iatrelocate.jpg
and with the air pump removed and plugged(look to the left side of pic)Ran the wiring in a loom.
http://www.bealer.org/plug.jpg
Old Mar 26, 2003 | 01:58 PM
JD30thZ28's Avatar
Where did you get that elbow from and how much was it? Any pics? Thanks
marlar98
Oct 21, 2015 02:02 PM
football4life
Oct 4, 2015 07:48 AM
Slayer
Aug 17, 2015 03:55 PM
colts0455
Jul 24, 2015 04:51 PM
Pampered-Z
Apr 14, 2015 05:38 PM
