still considering the 700R4 to TH400 swap in the 93 Z
I have this transmission sitting in my shed. TH400 short tailshaft.
If I was to swap it in, and not use a gear vendors overdrive unit, what rpm's would I be turning at say 60, 65, and 70 mph? I have 3.23's....
I am only considering doing this if it can be done relatively cheap. Hence why I am asking about running it without the overdrive unit. I can get a driveshaft custom length from the same guy that did my dad's 1957 Chevy, so thats not a problem. The only thing I am not sure of is how the shifter would work, and if I would need a different one and if it would fit in the stock console. Also not sure what I would do about the speedometer to get that to work. Any ideas?
Thanks guys
Thanks guys
Re: still considering the 700R4 to TH400 swap in the 93 Z
60MPH = 2539 RPM
65MPH = 2750 RPM
70MPH = 2962 RPM
