checking power to the fuel pump
Old Mar 21, 2003 | 12:20 PM
dajohns2's Avatar
other than checking the relay, is there any other fuses that i can check to make sure that my fuel pump is getting power.
my 96SS only has 81K on it. seems odd the pump would go out so fast.
Old Mar 22, 2003 | 06:31 AM
badass383's Avatar
My 94 shop manual says the relay is powered by the #5 fuse under the hood. If you have power at the relay then the fuse is obviously good. That is the same fuse that powers the PCM. #4 goes to the PCM also.
Have you checked the relay manually out of the car to see if the contacts pull in? Just because power is there doesn't mean the relay works.
Are you having problems?
RiverMutant96
Jan 30, 2015 09:21 AM
FIREBIRDMARK1
Jan 7, 2015 03:36 PM
ANDYZ28
Dec 29, 2014 09:13 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
