Does this work?????
Old Mar 21, 2003 | 09:41 AM
MILESF's Avatar
Question Does this work?????
http://cgi.ebay.com/ebaymotors/ws/eB...catagory=33557
Old Mar 21, 2003 | 10:03 AM
jonaddis84's Avatar
Not sure if it works, I know caspers electronics makes the same thing, so they probly just ripped off the design from caspers and made it.
Old Mar 21, 2003 | 10:10 AM
As always READ CAREFULLY. All you are really getting with that "kit" is an "adjustable" TPS sensor. This is accomplished because the new TPS they include has slotted holes. You can accomplish exactly the same thing, FOR ZERO COST, by opening up the screw holes in the stock TPS sensor so they are slots.
Then there is the question of "will I notice any performance increase"? Not likely. The TPS sensor in the LT1 is not adjustable because the PCM can read the TPS voltage at startup, set that number as "0% TPP" and prorate up to 100% TPP from there. MOST cars do NOT need an adjustment. As long as the closed throttle signal is between 0.20-0.90V, the PCM can handle it. Some people feel they get "faster throttle response" if they start with TPS voltage in the range of 0.50-0.65V, but that is open to question. Almost every stocker I have ever measured is already at 0.65-0.67V.
If you have your heart set on spending $51, at least check your stock TPS sensor voltages before you invest the money.
Old Mar 21, 2003 | 10:54 AM
Bastardcat's Avatar
Sounds like a "gimmick" to me.
Red Hawk 94
Mar 18, 2019 04:03 PM
blac94Z
Feb 18, 2015 11:36 AM
squarehead
Jan 15, 2015 07:02 PM
phoenix95
Jan 8, 2015 02:44 PM
phoenix95
Jan 8, 2015 09:14 AM
