How much HP /w this 383
Old Mar 20, 2003 | 04:59 PM
95TA8280's Avatar
I'm considering putting a 383 in my car...here are the specs. How much HP should I get to the ground with this and my current set up?
Old Mar 20, 2003 | 05:00 PM
PNYKILR's Avatar
From: Albuquerque,NM--5,600 feet above you sea-level cats
and the spec's are???
95TA8280's Avatar
Thumbs up
Opps.....
-385 .040
-5.7" rods
-3.75" crank
-fully ported airflow research heads 2.02" in 1.60" ex 195cc runner
-1.6 gold race rockers
-chrome moly pushrods
-heads and motor rebuilt 5000 non race miles(honestly)
-no nitrous or blower on motor ever
-58 mm BBK throttle body
-fuel rails
-24lb injectors
-LT4 hotcam
-new lifters(5000 miles)
-10.0-1
-water pump
-distributor(minus cap and rotor)think you should put new dont want to pull it apart later
-msd 8mm wires
-newly installed front and rear main seals
Old Mar 20, 2003 | 05:02 PM
PNYKILR's Avatar
Should make 400rwhp+
Good luck
Old Mar 20, 2003 | 05:05 PM
95TA8280's Avatar
It only has 5000 miles on it.....so how many miles do these things usually get?
Any other estimations on HP? What are good 383 power adders? Is a SC are good or bad idea?
Old Mar 20, 2003 | 05:43 PM
treyZ28's Avatar
From: looking for a flow bench so Brook and I can race
while the motor is out, swap that hot cam and for Christ sakes-
get bigger injectors!
Old Mar 20, 2003 | 05:46 PM
treyZ28's Avatar
why such low compression and short rod: stroke ratio?
who built this?
isit an "Lt1"
i dont see the point of an NA motor with less compression that stock on a bigger cam and short rods.
Old Mar 20, 2003 | 06:15 PM
Kreinmc's Avatar
That motor combo looks horrible.
Old Mar 20, 2003 | 06:22 PM
95TA8280's Avatar
Why is that?
Old Mar 20, 2003 | 06:33 PM
Mindgame's Avatar
Originally posted by 95TA8280
Opps.....
-385 .040
-5.7" rods
-3.75" crank
-fuel rails
-24lb injectors
-LT4 hotcam
-10.0-1
-water pump
-msd 8mm wires
Not a bad combination from the looks of it.
You are however gonna be running out of fuel if this thing makes the 450 hp (400rwhp) it should.
How did you arive at a 10.0:1 static compression ratio?
The cam is mild... not for horse lovers but it will make nice torque. Otherwise everything looks to be in line.
-Mindgame
Old Mar 20, 2003 | 06:44 PM
gb95zconv's Avatar
Well dont think its horrible, but it could be better. If you staying NA go with the longer 6 in rods , but I wouldnt sweat it if you allready have the 5.7s. You will most likely need at least 30# injectors.....the stockers were maxed out on my 350 hotcam setup at high rpm....Im going with 36#. Ild like to see at least the stock 10.5:1 compression...my app is going to be 11:1. With the hotcam you not going to get the full potential out of the motor....but if you like me and have to pass emmisions it will do. Im going with a 224/230 whitch is alittle bigger and should pass....we'll see.
Old Mar 20, 2003 | 06:56 PM
95TA8280's Avatar
What compression do you suggest? I would probably change the cam to on step higher, but like you said I need emissions. I would also prolly go with bigger injectors.
Old Mar 20, 2003 | 06:58 PM
Mindgame's Avatar
Question
Again, how do you know that that's the actual compression? Kinda tough to go that low with an LT1 stroker and flat-tops. What pistons? Any block decking?
-Mindgame
Old Mar 20, 2003 | 07:02 PM
95TA8280's Avatar
-Mindgame
That's the compression the guy told me who is looking to sell the engine to me....So whatever was in the list above is all I know.....
Old Mar 20, 2003 | 07:16 PM
treyZ28's Avatar
IF YOU DONT MIND me asking-
how much?
forged?
billet?
cast?
