Anyone with Hooker shorties...help needed
Old Mar 20, 2003 | 08:26 AM
DarkHorse's Avatar
At the end of the Y-Pipe there is a large flat flange, how did you guys connect yours to the cat/off-road pipe? What flange did you purchase to get this to work or did you use the extra flat flange that came with the headers and just weld it to the cat? Any pics? Thanks
Old Mar 20, 2003 | 09:49 AM
rickb@lynk.com
Guest
Posts: n/a
For what it is worth. I know the guy that put mine together cut the flange off on that end of the cat and rewelded a flange on. I thought he reused the one that he cut off but he may not have. I thought he did this both to clean out the cat and to change the angle of this flange so that the cat was parallel to the ground.
Old Mar 21, 2003 | 09:43 AM
Bud M's Avatar
At the muffler shop they will weld the extra flange to your cat. They will have to oval the cat inlet to fit them together.
Old Mar 21, 2003 | 09:55 AM
Zrag's Avatar
I got an off road pipe. They used the flange that came with the kit, made it oval and welded it to my cat back. Looks good. Also this helps if I need to remove the Y since the flange is there.
Parts Wanted
Mar 17, 2015 11:24 PM
HectorM52
Parts Wanted
Feb 11, 2015 09:33 AM
ModdedNerd
Jan 1, 2015 10:56 AM
NED4SPD
Sep 16, 2002 10:45 PM
mjcent922
Jul 27, 2002 12:42 PM
