My window is stuck....
Old Mar 20, 2003 | 12:31 AM
brandboZ28's Avatar
...DOWN! Is there an easy way to get the window up with the motor/switch out? I would like to get that thing up before I sleep or it rains, which ever comes first. I have a bag over it right now but I know Ill be missing something if I leave it that way in the morning. This is one of those times that I wish I had a garage. Thanks guys.
Bo
Old Mar 20, 2003 | 12:40 AM
12sec97Z28's Avatar
If you have some tools, you can get the window motor off track and pull the window up by hand, but that's not something quick or easy. especially if you haven't ever changed it before. original window motors have rivets that have to be drilled out. sorry if that doesn't help. if it won't go up at all, sounds like it might be a bad switch. if you have an understanding friend with an fbody who won't mind getting up at almost one in the morning, call him and see if he can bring his window switch over. at least it will get it up. and for older cars, just like older men, half the battle is getting it up. Good luck man.
Old Mar 20, 2003 | 01:19 AM
brandboZ28's Avatar
Thanks man, thats funny. Ill get it fixed, it just took me off gaurd and its about to rain. Oh well, the trash bag has been strategically placed over the broken window. Thanks again.
Bo
Old Mar 20, 2003 | 01:55 AM
cop01's Avatar
does it not even go up a cm at a time? mine did that before it just died. just pull up on the window (you may have already done this) and push the up switch and see if it will come up at all
Old Mar 20, 2003 | 11:06 AM
brandboZ28's Avatar
Not even a cm! I took it to a shop and they said that it sounded like the switch-$30. If it is in fact the motor though-$290 Im hoping for the switch.
Bo
Old Mar 20, 2003 | 12:01 PM
PatriotTA's Avatar
Bo
That's still luckier than I was. It was my whole regulator assembly (which includes the motor). $340!
Old Mar 20, 2003 | 12:25 PM
brandboZ28's Avatar
I actually just got the call. $350 for the motor, regulator and labor. I was gonna use that money for a pair of Nitto's. I guess not anymore. Thanks
Bo
Old Mar 20, 2003 | 12:51 PM
Blue89Bird's Avatar
you can get a new motor with a lifetime warranty from advance auto or any of those type stores for 85. Use brents install page and with a few hours of your time it will be under 100.
Old Mar 20, 2003 | 01:13 PM
12sec97Z28's Avatar
Yeah. Blue bird beat me to that one. You're crazy if you spend 350 bucks on one of these motors. any auto parts store will have them for less than 100 dollars, and the work can be done by even a novice (with patience) in an afternoon. hardest part is figuring out how it fits up in there, but with brent's install guide, it will go much more smoothly. i've gotten to where i can disassemble, change, and reassemble in about an hour or less.
Regardless, if the window motor was going, it would still go up, but it would overheat quickly and stop working after a few inches of lifting at a time. Your problem honestly sounds like a switch, and when i changed my door lock switch, the assembly cost me like 10 dollars from my dealer.
Old Mar 20, 2003 | 01:20 PM
Kris93/95Z28's Avatar
Shoebox also has a Awesome install guide we used to fix my friend's 97 Z28. This was simple drill three holes and drill out the rivets the rest is plug and play
It took about an hour from start to finish and that includes pulling the door panel, speaker, fixing the motor, and reinstalling everthing.
This ISN'T a $350 Dollar job!
Save your cash!
Old Mar 20, 2003 | 01:26 PM
http://home.swbell.net/shoebox/windowmotor.html
Here is Shoebox's Install.
Old Mar 20, 2003 | 03:36 PM
brandboZ28's Avatar
Thanks guys. The install seems pretty straight forward. I will be sure to let you know how everything turns out. Later.
Bo
Old Mar 20, 2003 | 04:55 PM
Calli's Avatar
$50 dollar motor from most places.... its a DIY job... very easy
OutlawPerforman
Oct 30, 2017 05:40 PM
IndyZman
Oct 22, 2015 02:17 PM
football4life
Oct 4, 2015 07:48 AM
z28cam1993
Sep 9, 2015 04:08 AM
Jul 10, 2015 02:23 PM
