removing passanger front o2 sensor
Old Mar 19, 2003 | 10:25 PM
blazzinbird's Avatar
is there any special truck to do this
i know it is a pita but i need some help
Old Mar 19, 2003 | 10:47 PM
I was able to get my O2 socket on it and poke the ratchet handle between the y-pipe and chassis just enough where I could hit the end of the ratchet handle with a hammer to break the O2 free. There was no other way to grab it with any force.
I think some other people have done it from the top with a collection of extensions and swivels, but I did not have what I needed to do that.
Old Mar 19, 2003 | 11:11 PM
$hawn's Avatar
when I did my passenger side O2 sensor I dropped the starter and used a boxed in wrench, but theres proably a couple ways to do it.
Old Mar 19, 2003 | 11:14 PM
how long did that take you to drop the starter
Old Mar 19, 2003 | 11:17 PM
95z28 -quicksilver's Avatar
From: Austin, TX or Texas State University at San Marcos
I guess its because of my AS&M Y pipe but i had no problem with my pass side. My problem lyed in the driver side. I had to wait to change my oil because the oil filter was in the way and wouldnt allow it to unscrew all the way. Oh and dont forget to put antiseize on the new ones!!!!!!!!!!!
Chris
Old Mar 19, 2003 | 11:38 PM
$hawn's Avatar
Takes like 10mins. to drop the starter, just take the two bolts out and wiggle it out, I didnt take the wires off thought, but I didnt let it hang very long either.
Old Mar 19, 2003 | 11:55 PM
cals400ex's Avatar
i took it out from the top. i took off the alternator so i would have more room. i ended up using 20 inches worth of extensions and an universal joint so i could try to get it from several angles. mine was in there pretty tight. i would have to say it is a pain in the *** to get out. i don't know if it would of been easier from the bottom. i don't know what kind of work is involved with putting the starter back on. i do know that those things are not really light. also, with new delco o2's, you are not supposed to put anti sieze on them. they come with it on the threads even if you can't tell.
i think i will remove the starter, now on my old firebird (94) the y-pipe was inthe way, i havnt looked under this car, but is the y-pipe inthe way at all?
Old Mar 20, 2003 | 06:08 PM
$hawn's Avatar
With a stock Y pipe, it'll come out without taking the Y pipe off, but if you have an auto tranny, you'll need to push those lines to the side, there is a bracket that holds the lines to one of the oil pan bolts, and you'll have to position the starter in a certain way for it to slip out.
linz
3rd Gen / L98 Engine Tech
Oct 22, 2015 07:59 AM
Jazsun
Dec 29, 2014 12:14 PM
Jul 4, 2005 05:00 PM
