how do i remove back seats?
Old Mar 19, 2003 | 12:00 PM
1.8ttolt1's Avatar
i tried search and didn't find anything useful. can anyone help me out?
Old Mar 19, 2003 | 12:04 PM
Kris93/95Z28's Avatar
The part where your butt goes there is one 10mm? bolt on each seat remove it and the bottom part pulls out. As far as the big back seat piece I am unsure since I never pulled it.
Old Mar 19, 2003 | 12:05 PM
chesee48's Avatar
Its very easy.
To remove the seats, you unscrew the bolt underneath, by the front on the seats. To see them, your goign to have to lean over on the ground/floor and you'll see it. One for each seat. That'll remove the seats.
As for the backrest part, you have to unscrew the seat belt bolts etc and the rest should be pretty explainitory when u are this far.
Fairly easy job. i did it when i swapped out for my leather
Old Mar 19, 2003 | 12:19 PM
Fastbird93's Avatar
If you're gonna to that for weight savings, go ahead and remove the seat belts too. They're pretty hefty, and all they take is a couple of Torx bolts on each belt and they're outta there.
Old Mar 19, 2003 | 12:53 PM
GREGG 97Z's Avatar
The fold down seat back and belts are the only real weight savings, together it all weighs around 30 pounds maybe more. The seat back is only held on by two bolts, one on each side. I removed the back and the seatbelts then reinstalled the two seat cushions. The cushions weigh maybe 1 lb each if that, they are just foam. It looks much better back there with them left in, plus it leaves the remote possibility that someone could still sit back there
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
Snoman73
Nov 17, 2014 07:22 PM
ur2slo50
Sep 10, 2002 07:27 PM
nautilus
Aug 22, 2002 11:49 PM
firebirdude
Aug 7, 2002 07:31 AM
