Autocross and Road Racing Technique There is more to life than a straight line
bilstein coilovers and general?
Old Mar 19, 2003 | 12:49 AM
kandied91z's Avatar
Question bilstein coilovers and general?
anyone running a set of these?
i am looking for some coilovers for my car and i love my bilsteins...however getting the proper info on my year is hard so i thought i'd check the newer years.
what about koni, h&R, tokico, qa1, hal, ground control and the many others out there that i've forgotten.
any one running any of these on their cars? what are your thoughts?
Old Mar 19, 2003 | 01:19 AM
Dr.Mudge's Avatar
The only issue is without revalving your shocks, your going to be very limited in spring selection. I went with Koni DAs because in part, I wasn't sure what spring I was going to stick with.
Old Mar 20, 2003 | 12:24 AM
kandied91z's Avatar
so what did you end up with spring rate wise?
do you drive it on the street? how different is it from the stock ideal?
i really like my bilsteins........however, my coilover kit will not fit it so i'm either selling the kit and trying to find a similar alternative or will just use konis since they do work......i didn't much care for the reds very much though.
Old Mar 20, 2003 | 12:31 AM
Dr.Mudge's Avatar
Reds are sport only, the yellow are 'racier.'
I have a 4th gen car, non-coil overs, and 600# fronts. You have even more spring options in a non coil over than I do, but of course there are reasons to have a coil over.
Old Mar 20, 2003 | 01:04 AM
kandied91z's Avatar
Smile
thanks for your help dr.mudge!
well i have to run a coilover now and i can't find anyone with good working product knowledge on what i should do or who i can talk with.
i wanted to go with a bilstein strut with a built in coilover setup like they show on their site but i haven't been able to get a working part number or speak with anyone on how i can go about it. however, they are quick to tell me they can revalve my stock strut with their equipment?
i know both koni and tokico make a strut that is the same stock diameter as my own but i'm thinking against using a coilover sleeve and would rather get a unit that is built all in one since the sleeve doesn't look to sound. is there anywhere i can go to talk with others that have coilover setups on their cars by any chance?
14
Aug 11, 2015 12:03 PM
KYWes
Aug 10, 2015 07:03 PM
Aug 7, 2015 08:52 AM
fundone2000-RZ
Pacific
Jul 21, 2015 07:21 AM
