LT1 scanmaster hookup ?
Old Mar 18, 2003 | 01:42 PM
95BlackTA's Avatar
My car came with my lt1 scanmaster already hooked up..a while back, after driving on a rough road, it stopped working...the wires were loose, you could tell how it would turn on and off over bumps. Mine is located on the left dash..and im wondering how is this thing hooked up....does it go down to behind the fuse panal ont he left of the dash..does it go thru the firewall to the computer?
Thanks guys...id just like to know where to look before taking apart my car.
Old Mar 18, 2003 | 01:51 PM
Bastardcat's Avatar
I can't answer your question but thought maybe this link may be able to help you out:
www.bfranker.badz28.com/fbody/scanmaster.htm
It's an install link, but it may help shed some light on your question.
94blkTA's Avatar
They are generally hooked into the port under your dash on the drivers side. The only hookup with 3 wires, a ignition, a ground, and one that goes into the port to gather data.
One wire goes to a +12V power source, preferably (but not necessarily) "switched" with the ignition. One wire goes to a good ground... any screw under the dash into the sheet metal. The third wire is the data wire and connects to the tan wire in the ALDL connector near your right knee.
Wiring instructions are in my online "ScanMaster" writeup:
ScanMaster Writeup
Old Mar 18, 2003 | 02:19 PM
95BlackTA's Avatar
Aight fixed it..thanks guys
thenewkid
Nov 29, 2014 04:54 PM
Rich_z28
Sep 13, 2002 03:35 PM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
ChrisFrez
Aug 12, 2002 11:50 AM
