before applying gaskets...
Old Mar 18, 2003 | 11:13 AM
corkss's Avatar
Before applying gaskets aren't you supposed to rub mineral spirits or somethinglike that to get rid of any oil on the metal...??
Im installing my headers and I'm basically asking what to do to prep the gaskets or work area
Thanks, Matt
Old Mar 18, 2003 | 11:15 AM
I always clean gasket surfaces. Typically, I use something cheap like alcohol and a lint free rag.
Old Mar 18, 2003 | 11:16 AM
jonaddis84's Avatar
What kind of gaskets are you using? Anyway, just clean off the mating surface as best as you can, with headers its mostly just get bigger chunks of stuff off so they dont leak, you have to worry a lot more about timing gaskets and head gaskets.
Old Mar 18, 2003 | 11:46 AM
corkss's Avatar
Do you guys smear gasket sealer on header gaskets at all
Thanks in advance
Matt
Old Mar 18, 2003 | 11:50 AM
97FormulaWS-6's Avatar
Depends on which gaskets....
Normal ones I use "High-Tack". Certian ones I used a high-temp RTV, and others I use nothing at all, it kinda depends on where and what the gasket is for.
For normal header gaskets I'd most likely use some "High-Tack" it comes in a small spray-can and you coat the gaskets with it. it works excellent for sealing things like that.
I'm putting my Hookers in in a few weeks, but I'm using the ultra-copper gaskets, thus no sealent required.
Old Mar 18, 2003 | 12:27 PM
Z28SORR's Avatar
Using gasket sealent on header gaskets is useless do to the high temperatures. Just make sure both surfaces are clean, flat and dry. Most "blow outs" are caused by the bolts coming lose. Get locking ones or check them often.
tommalcolm
Sep 11, 2015 03:39 PM
USN06
Sep 7, 2015 03:30 PM
Jul 17, 2015 02:47 PM
whitehooptie
Jul 12, 2015 06:10 PM
Jul 10, 2015 02:23 PM
