Fuel system
Old Mar 18, 2003 | 10:07 AM
BLOWN25TH's Avatar
Fuel system
I currently installed a Walbro 340 intank and removed the stock pump along with the ATI's inline. I need to know if the 340 alone will provide enough fuel along ATI's FMU for my application? See below.
Old Mar 18, 2003 | 11:41 AM
IDOXLR8's Avatar
I think the fuel pump will supply your car without and FMU. You may also want to install an Kenny Belle Boost a pump.
Old Mar 18, 2003 | 08:13 PM
svt1106's Avatar
put the inline back on its just extra insurance man!!! If you have a afpr you can always tune your fuel system that way!! With power adder cars I would always rather have too much gas as not enough. Goo luck man
Old Mar 18, 2003 | 11:46 PM
JordonMusser's Avatar
West South Central Moderator / Special Guest
the inline will actually hurt flow.. so leave it out
Old Mar 19, 2003 | 09:00 AM
Alvin@pcmforless.com's Avatar
Usually these intake pumps are more geared towards flow and not PSI where as the inlines are geared towards PSI.
We tried using a FMU and a 255 intake pump and it wouldn't build over something like 65psi. Adding a T-Rex (which orginally came in the kit) got it up about 15psi.
As far as using a 7730 (speed density) do a search for speed density and see what i've said about it in the past.
YOu have a good option of switching to a 7749
Old Mar 19, 2003 | 02:40 PM
rooster-
you must get the high pressure 255 intank. the trex flows <255lph, its something like 210
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
95maroboi
Jun 7, 2015 12:18 PM
Jul 4, 2005 05:00 PM
