lt4 intake
Old Mar 18, 2003 | 09:22 AM
alexis01's Avatar
lt4 intake
Just wondering about the difference between an lt4 and stock lt1 intake.. Basically any power gains? HP differences..
Old Mar 18, 2003 | 10:08 AM
CODY BEHNKE's Avatar
A LT4 intake isn't a direct replacement for the LT1, It will not bolt up to the heads.
Old Mar 18, 2003 | 10:53 AM
GREGG 97Z's Avatar
There are no noticable power gains from the LT4 intake from what I hear. I thought it did bolt up to LT1 heads though? It's just that the intake ports wont match the LT1 head ports. I think people have used it with stock heads but they needed to port match the heads to match it. Anyway, if you're getting it for looks just have your stock manifold powdercoated red, that's what I did
Old Mar 18, 2003 | 11:01 AM
Mikael's Avatar
LT4 heads are a raised runner design, hence the need for an intake to fit.
Old Mar 18, 2003 | 11:46 AM
Go to this link and look at the cutaway sections of the LT1 head intake port vs. the LT4 head intake port. You will see a difference in the way the rail for the valve cover is set up. That is enough of a difference to require some machine work on the LT4 intake, to bolt it to the LT1 head.
LT1 vs. LT4
After you get it on there, there is absolutley NO evidence that there is any gain. In fact, there might even be a loss... no one has ever measured it.
The LT1 intake flows exceptionally well, unmodified.... and will support extremely healthy ported LT1 head flows. The LT4 intake is really of benefit for LT4 heads, and even then requires some significant porting to support the kind of flows ported LT4 heads are capable of.
pimpss96
Feb 12, 2015 01:28 PM
MadMav
Feb 6, 2015 11:02 PM
ModdedNerd
Jan 29, 2015 07:23 PM
95chwagon
Jan 13, 2015 09:19 PM
