Which Header Bolts?
Old Mar 18, 2003 | 01:04 AM
Laymaster's Avatar
Which Header Bolts?
I can order stage 8 locking header bolts in two different sizes, one is 3/4" long, the other is 1" long...which one do I order?
I am going to use these in conjunction with MAC headers, if it matters...
Old Mar 18, 2003 | 01:12 AM
1QUIKTA's Avatar
I have the ARP 6pt and love them. I only had to retighten 1 or 2 times when I first put them on (within 50 miles I think).
Old Mar 18, 2003 | 01:13 AM
97CamaroZ28R's Avatar
I would use Stage 8 3/4" header bolts. These are the ones I used with my Hooker LT's. The 1" bolts might be too long. They do require some modification to the locks, but this is easy to do with a dremel tool.
Old Mar 18, 2003 | 03:44 AM
Est96Z28's Avatar
I would use 1", because I have myself 3/4" w. hooker shorties and they were really on the edge, so short that I didn't dare to tighten them up much. You can use 1" without any problems.
Old Mar 18, 2003 | 06:37 AM
Don 97 SS's Avatar
Ditto, I've had my headers on with ARPs for over 5 years and no problemos! Get the 1" lengths for thick flanges as 3/4" get a little short in the hole.
Old Mar 18, 2003 | 08:03 AM
dabear95's Avatar
I used regular bolts that came with my headers. I just tightened them down after every cool down. After the 2nd time, most stayed tight. After the 3rd time, they never loosen.
Now I just check them once in a while when I check my oil.
Jason
Old Mar 18, 2003 | 08:47 AM
GREGG 97Z's Avatar
I used 1" 12pt ARP's with mine. They fit fine and with the longer bolts there is less chance of stripping the aluminum threads when cranking down on them.
Old Mar 18, 2003 | 08:50 PM
Bud M's Avatar
I'm happy with my 3/4" Stage 8s. I tried a 1 inch on one pipe when I was putting on my Lokar dipstick and I couldn't get it in the hole because the header pipe kept it ffrom being able to line up right. I'd go with the 3/4" bolts.
Old Mar 18, 2003 | 09:07 PM
mojo's Avatar
I had the Stage 8 bolts,but switched to ARP on the AS&M headers w/copper gaskets-The Stage 8's are good ,but a pain if you have to replace a header gasket - ARP's and copper gaskets are easier to deal with-if the bolts back out a little,put a wrench to 'em and tighten.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
94Z28LS1toLT1
Apr 7, 2015 05:37 AM
maybe2fast
Mar 16, 2015 09:45 AM
SavageZ28
17
Jul 14, 2002 11:04 PM
