Midwest Illinois, Indiana, Michigan, Ohio, and Wisconsin
Looking for some heads
Old Mar 17, 2003 | 10:04 PM
pskel350's Avatar
well once again i have changed the plan for my engine
So now i am looking for a cheap set of heads. around 64cc, atleast 1.94/1.5 valves. not looking for anything special, they just have to get me through this season. Really just something that i can put new springs in and clean them up and go. i can put new valve seals in, but dont really want to mess with having a valve job done unless the price is right
BTW....i will have a set of 081 ported and polished for sale in a week or two. about $100
also have a black automatic console out a 96 camaro forsale...$60 shipped
Old Mar 17, 2003 | 10:12 PM
IrocSS85's Avatar
what style heads you looking for? aftermarket, stock, alum. , what? what year is your eng? why dont you use the heads you mentioned for sale?
chris
Old Mar 17, 2003 | 10:33 PM
pskel350's Avatar
looking for primarily a pre 86 head. i just want a stock head, cast or aluminum doesnt really matter. i will settle for a 87 or newer though if a good set is to be had. dont want vortech's though.
i dont want to use the 081 because they are 58cc, and will raise CR to much that i will have to use premium gas and gas prices are going to suck this summer
my engine is a 1974 block 350
Old Mar 18, 2003 | 07:39 PM
pskel350's Avatar
ttt
Old Mar 18, 2003 | 09:28 PM
IrocSS85's Avatar
well then I hacve some descent heads for ya. I got some 64cc camel humps from a 70 chevelle ss. I ported them and gasket mathed them. thevalves wer cleaned and lapped in which clearly showed the valve angles and the seats and there was no need to have a valve job done. 1.94 valves w/almost new valve springs good to .500 lift. rockers included if you want (stock) and some valve covers painted. these heads were on my eng. in the early part of last year before I got a good deal on some trick flow heads. w/a flat top piston and .500 lift cam it went 13.3 w/1.82 sixtys. they had lots of power down low. and still pulled untill 7000 rpm. dont know for sure where the power drops off yet cause havent been on a dyno yet, but they sure felt like they were still puling. the only problem w/them is 3 of 4 valve seals didnt get on correctly and are lifted under the spring and need to be replaced and 2 valve cover bolts were helicoiled by someone else before i got htem and they arent the correct angle. so you need to slot the two valve cover holes slightly. no big deal. $150 you pick up. email if interested.
chris
Old Mar 18, 2003 | 10:30 PM
pskel350's Avatar
sent you an email
Victor Lamb
Aug 26, 2017 02:52 PM
Roadie
Feb 16, 2015 10:34 AM
MadMav
Feb 6, 2015 11:02 PM
NewsBot
Jan 29, 2015 07:10 PM
NewsBot
Dec 28, 2014 06:20 PM
