Changed front brake pads, now CLUNK CLUNK from both wheels
Old Mar 17, 2003 | 09:57 PM
Achilles97's Avatar
Angry I think Napa f'ed-up my brake rotors!
Today I changed out my front brake pads to some Hawk HPS pads, and I had my rotors resurfaced at Napa.
The install went fine, everything went in without a problem. I flushed through all the old brake fluid as I added new fluid and did the bleeding.
I took it out for a test, went up to 25mph and stepped on the brakes with normal effort and I heard CLUNK CLUNK CLUNK from the front wheels, both sides. I even felt the clucking in the floor of the car.
The clucking was at a regular pattern and it slowed as the car slowed. The clunking got stronger as I stepped on the brakes harder.
I went up to 25mph and braked to a stop 3 times with the same result.
Afterwards I jacked up the car and spun each wheel, and both sounded like the brakes rubbed at a certain part in the revolution of the wheel. Is it possible that Napa screwed up the resurfacing of the rotors?
Old Mar 18, 2003 | 08:09 PM
lastlaf's Avatar
Last time I changed my rotors/pads I had a similar noise. After the break in the noise went away. You might want to give it a week or so to see if it goes away.
Old Mar 18, 2003 | 11:25 PM
Achilles97's Avatar
Thanks for the reply lastlaf.
I put the old brake pads back in and everything was normal, so that means the rotors are fine. I put the new pads back in, and I had problems again. I was pretty po'ed by now, so I just drove around thinking that my anger would scare it into working properly, and it did actually get a little better.
I think the problem is that the rotor surface is pretty rough, it wasn't fininshed smooth like I've seen before, they have a surface exactly like a vinyl record. I think what's happening is the pads are catching on the rotor too hard because the rotor is too rough. I'll drive around for a while until to rotors smooth down, I think that should fix it.
Old Mar 18, 2003 | 11:34 PM
1994TransAm's Avatar
i'm sure those pads didn't seat right, and it will go away...if not...send the pads to me
Old Mar 18, 2003 | 11:56 PM
Inutero's Avatar
It may be your caliper, sometimes the piston(or whatever is in it) messes up and doesn't retract all the way on one side.
Jazsun
Dec 29, 2014 12:14 PM
Red97LT1
9
Dec 17, 2014 06:13 PM
Jul 4, 2005 05:00 PM
