Another question about doing !TB bypass
Old Mar 17, 2003 | 08:47 PM
MrZ's Avatar
MrZ
After looking at this site: http://www.geocities.com/MotorCity/6647/ta93/tbody.htm and talking to a few people, I realize that I need some of this 'hard line' to put in between the two hoses. What is good for that? Should I go buy a piece of something? How big do I need it?
Old Mar 17, 2003 | 08:52 PM
Prorac1's Avatar
Any steel tubing will work. Go to NAPA or Autozone and get a piece of fuel line or something. Hope this helps, Prorac1
Old Mar 17, 2003 | 08:56 PM
n2ceptor's Avatar
I used an 3/8 airhose repair connector.. It was about two inches long, but thats for an 93', because the hose that goes to the thottle body is part of the radiator hose....
But you can find a connector at a hardware store in the plumbing dept... cost around a dollar...
93Z WIll
Old Mar 17, 2003 | 08:58 PM
96ltz's Avatar
A 3/8" connector like in the picture on this link http://www.plumbingsupply.com/barb.html
You can get these at most auto parts stores, hardware stores (in the plumbing section, ect.
Old Mar 17, 2003 | 09:19 PM
Euclid's Avatar
Or you could use the connector on the throttle body itself, to make this a truly *FREE* mod.
Just take the metal connector off your throttle body, and hose-clamp a line to each end.
Old Mar 17, 2003 | 09:24 PM
5thCamaro's Avatar
why do you even need a adapter, all I did was remove the line from radiator to the tb and move it to the return line on the other side.
Old Mar 17, 2003 | 09:25 PM
96ltz's Avatar
Are you sure you need one? Look here http://csce.uark.edu/~jgbertr/rb/tb_bypass.jpg
Old Mar 17, 2003 | 09:32 PM
You don't need any added parts if you have a 1995 and up.
rotoruter2001's Avatar
i think the 95s you can just use the one hose and connect it to the other end with out using that connector. essentially you can remove one of the hoses and just use the one to connect the two.
Old Mar 17, 2003 | 09:45 PM
MrZ's Avatar
MrZ
Ahhh...I'll have to try that...so much for following instructions LOL
Travis
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
lbrowne
Nov 13, 2011 04:25 PM
slocody
Feb 10, 2003 01:04 PM
RedLineRev
Jan 23, 2003 03:51 PM
