Draco
03-17-2003, 12:58 PM
hey guys... I could use a hand or two this afternoon if anyone is able. I need to drop the y-pipe and connect a ground wire. also need to check plug wires and fuel injectors. I could do this myself but it helps having a couple of extra hands for the exhaust.
I am planning on getting to Shaun's at 3pm. Anyone else able to come? Mike are you still able to?
sleeperZragtop
03-17-2003, 01:24 PM
Can you pick me up? Call me later:)
Draco
03-17-2003, 02:07 PM
I sure can :)
I will call ya l8r.
JeffK95Z
03-17-2003, 04:00 PM
Sorry Craig, but not I... I don't get home from work until 6-6:30ish and i'm wiped then...
but no doubt Mike and perhaps some others will be all you'll need!
Good luck man!
I noticed Shaun posting in the LT1 Tech forum about your valve covers not going on, did you guys get that straighted up?
jeff
Draco
03-17-2003, 04:31 PM
Good luck man!
jeff
Well, the aluminum valvecovers would simply not fit.... they won't clear the roller rockers. We had to cut most of the cross-webbing on the stock covers to get them to fit, and I am leaking oil out the back of the valvecovers now :(
I think we will be ok. Mike and I should be able to handle the y-pipe
CoryM
03-17-2003, 05:28 PM
I might be able to come by. Ill see you there if so. Need any tools?
Cory
