What cam is this
Old Mar 17, 2003 | 01:33 AM
smokindastangs's Avatar
What cam is this
Is this the cc306 ? Grind: 306 Lift: .555''/.555'' RPM Range. It is called Comp Pro-Magnum 306s. I am guessing that it is the cc306. If this is true then will it pass emissions?
Old Mar 17, 2003 | 03:34 AM
NiteRider's Avatar
cc306 has .510/.540 lift on a 1.5r ratio. That is probably a custom grind cam on the magnum series lobes. What are the duration numbers?
Old Mar 17, 2003 | 05:27 PM
306S Solid Magnum™ is an excellent grind for large cubic inch Pro-Street type engines. This cam has tremendous high RPM power and needs to be used with headers, intake and higher compression. Radical idle. Grind: 306 Lift: .555''/.555'' RPM Range: 3000-7000 Comp Cams lifters feature precision ground bodies for long life and durability
rideordie
Nov 5, 2019 04:52 PM
alex5366
Feb 17, 2015 08:12 PM
Queens94z28
Dec 20, 2014 09:11 PM
Queens94z28
Nov 20, 2014 06:03 PM
