My car thinks i have a door/trunk open..but i dont
Old Mar 16, 2003 | 09:43 PM
joink's Avatar
I was doing some work on my car (brakes, oil) and then when i was done i reset my computer to try to get rid of a fuel pump code i had a while back. Then later when i reconnected the battery i went to drive and my interior lights would not turn off. I checked to make sure that all my doors and trunk were closed and there was nothing in the way. I also checked to make sure that the **** on the dash was in the right place. My factory alarm will not beep anymore either but the keyless entry and trunk buttons all work and will lock and unlock the doors.
Has anyone ever had anything like this happen? I have no idea what to do... tomorow im just going to try reseting the computer again unless you guys can give me some suggestions. Thanks
Old Mar 17, 2003 | 07:51 AM
Black97Z's Avatar
I've had this before, it turned out that my door switch wasnt getting a good ground any more. I'd take your driver's side door switch apart and give it a good cleaning. Then when you reinstall it, put down some di-electric grease, so it makes a good connection.
Old Mar 17, 2003 | 08:00 AM
Don't know about the dielectric grease, since it's purpose is to reduce conductivity.
Old Mar 17, 2003 | 03:36 PM
joink's Avatar
Besides the drivers door what other sensors are there... just passenger door and trunk? The hood doesnt have a sensor does it?
Old Mar 17, 2003 | 06:02 PM
Terran2k's Avatar
ummm If its one of the door sensors....won't it make that ding ding ding noise all the time since it would think one door is open? Im not 100% sure on that but maybe some1 else is.
Old Mar 17, 2003 | 06:05 PM
KeVMaN's Avatar
you try clicking down the little wheel next to your headlight controls?
Old Mar 17, 2003 | 06:40 PM
joink's Avatar
Yes i checked the **** on the dash... and as far as the beeping thats for leaving the keys in the ignition. Ive checked the sensors and they seem fine. Does anyone know where they are actually controlled? is it a relay or in the computer?
1996LT1Z28
Middle Atlantic
Dec 4, 2014 09:37 PM
1996LT1Z28
Dec 4, 2014 09:20 PM
tds1213
Nov 27, 2014 12:55 PM
USAirman93
Nov 24, 2014 03:37 PM
YellowTransAm350
Mar 2, 2003 03:38 PM
