What does a high Stall torque converter do to your dyno numbers?
Old Mar 16, 2003 | 09:28 PM
ucrazymonkey's Avatar
Take my dyno numbers listed in the sig. Will the torque converter change the output number for my RWHP? I would imagine that 290 RWHP is the true reading. As for the RWTQ of 347 is it mulitplying it up? where do I get my basis for my RWTQ numbers? From what RPM? And also when it spikes on the graph is the the torque conveter locking up?
Old Mar 16, 2003 | 10:37 PM
rskrause's Avatar
Moderator
Re: What does a high Stall torque converter do to your dyno numbers?
Most converters will not lock up under WOT. When you have an automatic on the dyno the torque spikes up when the converter flashes, then comes back down as the revs rise. Peak numbers, ignoring the "artificial" peak when the converter flashes, are 5-10% lower than with a manual tranny, you stop getting torque multiplication pretty quickly as the revs rise after you hit WOT.
The looser (higher stall) the converter, the greater to loss in rwhp. Cars with relatively poor power to weight ratios are quite a bit slower with automatics than with manual tranmissions. It's only at pretty high hp:lb that an automatic has an advantage at the track, but it's always lower on the dyno.
Rich Krause
Steve69SS396
Track Kill Stories
15
Aug 10, 2015 02:45 PM
armedtrigger
Feb 24, 2015 08:30 PM
PCLZ28
Parts Wanted
Feb 12, 2015 11:35 PM
marine1bird
10
Jan 25, 2015 12:02 AM
Collector Car
Dec 17, 2014 01:12 PM
