Headers and wires
Old Mar 16, 2003 | 08:23 PM
JLMZ28's Avatar
Headers and wires
I am installing Hooker long tubes on my 97 z. Do I need to use those over the valve cover wire looms? I thought you could use the stock setup. If you can use the stock setup, any tips or tech would help.
Thanks, Jared
Old Mar 16, 2003 | 08:43 PM
JLMZ28's Avatar
Has any one not used these on there car with longtubes
Old Mar 16, 2003 | 08:46 PM
scott95ta's Avatar
I you want few troubles with your wires, go with the over the cover type or just longer wires to get around the headers. The stock length wire WILL get burned up on the headers, they just are not long enough.
Old Mar 16, 2003 | 09:38 PM
Achilles97's Avatar
Ya, I agree. I suggest just biting the bullet and go over the valve cover. You can see a pic of mine here
It's not a great pic, but it's the best I have...
Old Mar 16, 2003 | 09:57 PM
JLMZ28's Avatar
Thanks for the advice. If I do go with longer wires, what do you suggest. What is the cheapest place to get the loom if i decide?
I have just finished removing all old parts and heat taped all wires. Now in go the headers tommorrow. Hopefully it goes as smooth as it has been.
Old Mar 16, 2003 | 09:58 PM
mobleman's Avatar
thunderracing.com is having a group purchase on the Taylor OVC plug wire set. Go to the group purchase section and check it out if interested..
Old Mar 16, 2003 | 10:02 PM
JLMZ28's Avatar
I forgot to mention that my wires are not stock. Ihave accel extreme 9000, 8mm. Will those be long enough.
Old Mar 16, 2003 | 10:08 PM
JLMZ28's Avatar
If the wires are not long enough and i use those looms, do the vertical style work just as well. The reason I am concerned is I would like to get a nice pair of polished valve covers and those looms wouldnt look as good. The vertical would show the new valve cover more. There only 3.00 dollars more, but if I have to use the regular over the valve cover style oh well.
Old Mar 16, 2003 | 10:39 PM
ZDriver96's Avatar
I just got done installing the long tubes. Plug wire #5 looks like it'll get burned so i just rigged it with a longer wire over the valve for now. I do want to try running a normal wire that way and see if it will get burned or not.
Old Mar 17, 2003 | 09:00 AM
EviLBoX's Avatar
I just thought I'd add that you don't have to route your wires over the valve covers, you can leave them in the stock location as long as you make sure none of them are close to or touching the headers. I know there are some people on this board who have successfully left them in the stock location.
Old Mar 17, 2003 | 12:48 PM
dabear95's Avatar
I ordered a set of magnecor wires cut longer for an LT1 with headers. I installed the wires under my edelbrock shorties. The wire that is closest in on #6. With the taylor heat boots, the boot is about 3/8 of an inch from the primary.
Jason
94Z28LS1toLT1
Feb 28, 2015 08:33 PM
Jul 4, 2005 05:00 PM
GigaMp3z
Feb 20, 2003 02:57 PM
Skull Leader
Aug 10, 2002 11:01 AM
CobraEatr
Jul 23, 2002 06:32 PM
