Resistor for OBDI
Old Mar 16, 2003 | 02:20 AM
ollie-99's Avatar
Resistor for OBDI
Where do i solder on the resister on the OBDI pcm cuz i did an OBDII to OBDI conversion and i heard i must do this or get a new knock sensor
Old Mar 17, 2003 | 05:54 PM
96ZRDR's Avatar
Get a 3.9k OHM resistor. Cut the Knock sensor wire, and put the resistor on the end, then ground the other side to the frame.
Simple.
Remember this totally eliminates the ability of the pcm to cut timing in case of real knock. Be careful.
If you are replacing the knock sensor, remember that is also serves as a water plug. Protect your eyes. You must use an OBD-1 style knock sensor.
aj2494
Mar 12, 2015 10:17 PM
Cream
Mar 3, 2003 02:52 PM
mtxpert
Feb 6, 2003 09:53 AM
Dan K
Oct 28, 2002 05:27 PM
Dan K
Aug 3, 2002 09:12 AM
