Change in Pushrod length
Old Mar 16, 2003 | 12:47 AM
94foormula's Avatar
Im planning my head cam build up and something I came across was different pushrods. I know I want to get chromoley but what length? The heads are getting milled to bring my compression up to 11.5:1 with an impala gasket. Is there anyway to figure out what length you need? Will it need to be shorter or longer?
Old Mar 16, 2003 | 01:48 AM
sssalah's Avatar
A shorter pushrod is not what you need. There are too many variables such as cam base circle, block deck, gasket thickness, head milling and valves length.
You'll not know the correct length unless you measure it, by a pushrod checker.
I've a small base circle cam, 0.020" decked block and a thiner gasket. Ysing the pushrod checker I found the perfect length was the stock 7.200".
Old Mar 16, 2003 | 07:26 AM
rskrause's Avatar
Moderator
Just to second sssalah's opinion (he seems to know his stuff): it needs to be checked when significant changes (such as milling the heads) are being made to the combo.
Rich Krause
HectorM52
Jul 30, 2017 11:46 AM
Midnight_Z
Parts Wanted
Apr 3, 2015 12:46 AM
armedtrigger
Feb 24, 2015 08:30 PM
chuyz28
Feb 19, 2015 12:50 AM
Roadie
Feb 16, 2015 10:34 AM
