Modifications
Old Mar 15, 2003 | 02:13 PM
Speede's Avatar
Modifications
How many mods can you do to the car before you start to void the warranty?
Old Mar 15, 2003 | 02:22 PM
kahouna23's Avatar
This is kinda a tricky question....The only time your warranty will be voided is if the problem is caused by something you've installed that's aftermarket. You can mod the heck out of your car and not worry about warranty work, unless like I said the problem stems from an aftermarket add on. Most modification parts these days are tested for this reason. Who wants to buy an intake and have numerous problems after installation. Parts are supposed to help your cars performance not hinder it. Dealerships will swear by it all day long that aftermarket parts are not tested, and 9 times out of 10 are the cause of problems. BULLS*$T!!!!! Don't let them tell you that. Look on the lot, I bet you see at least one Chevy truck with aftermarket exhaust on it which is a dealer add-on. I've been dealing with this for the last 4 years now. If all else fails, remove everything possible to eliminate any question whether or not your aftermarket mods are the cause of the problem. Have fun.......
Old Mar 15, 2003 | 05:07 PM
blue95's Avatar
well put thats pretty much the answer I got as well when I asked someone about that.
Old Mar 15, 2003 | 08:20 PM
Bliggida's Avatar
spelling may be off, but the Mangnuson Warranty act covers you, so long as
A) you don't crack open the motor and modify the internal components, or
B) a bolt on directy causes a problem.
Air intakes, exhausts, pulleys, even superchargers are covered depending on your boost level.
Old Mar 16, 2003 | 02:03 PM
kahouna23's Avatar
Could you explain a little more about this? I have never heard of this before and may end up being quite helpful when I get my Powerdyne installed.
Old Mar 17, 2003 | 09:55 AM
GrdLockV6's Avatar
Put a new cam, a supercharger, and nitrous on it. The dealer won't care, they'll be happy to honor your warranty!
football4life
Oct 4, 2015 07:48 AM
gonzo275rltw
3rd Gen / L98 Engine Tech
Sep 7, 2015 04:46 PM
gonzo275rltw
Sep 5, 2015 06:26 PM
gonzo275rltw
Sep 5, 2015 06:24 PM
gtstriker86
Aug 26, 2015 10:56 PM
