proper way to change or add coolant??
Old Mar 15, 2003 | 12:14 PM
1.8ttolt1's Avatar
is there a proper procedure for adding or changing out coolant? i read somewhere to make sure there is no air in the system using some valves? Can any one clear this up please.
Old Mar 15, 2003 | 12:42 PM
1.8ttolt1's Avatar
oh yeah, and i am gonna flush the heater core also. when i am running the water through the core where do i drain it? these are the instructions i am gonna follow, are they missing
www.vifbody.ca/articles/displayarticle.php?id=4
Old Mar 15, 2003 | 12:53 PM
RENE95Z's Avatar
Those instructions will do you just right. I believe they are the ones I used. As far as flushing the heater core, just let it fall where it may.
However, I used a pistol grip nozzle on the end of the hose, just don't squeeze too hard and let too much pressure go in or you just may get a face full of whatever is clogging your heater core.
While your car is idling, just take a flathead and rag and open the bleeder valves and let any air out that may be in your system. If there is, you will hear it hiss as it escapes. When coolant starts to come out of the valves, close her up and you're good to go.
Old Mar 15, 2003 | 12:56 PM
1.8ttolt1's Avatar
what about the bleeder valves??how do i use them to get air out? just loosen them to release air, then tighten again?
Old Mar 15, 2003 | 12:58 PM
RENE95Z's Avatar
I edited my first response while you were posting, just reread.
Old Mar 15, 2003 | 01:13 PM
1.8ttolt1's Avatar
thanks, you are awesome
DirtyDaveW
Dec 1, 2016 05:37 PM
Collector Car
Jan 5, 2015 10:58 AM
guionM
13
Sep 5, 2002 09:58 PM
91Bird305
Aug 8, 2002 12:36 AM
