HELP, SES code driving me insane
Old Mar 14, 2003 | 11:38 PM
Aeromaks's Avatar
Ok, so I come home from the track a few days ago and all is good.
2 Days after, today, I get in the car, and after a few mins, the SES light comes on, and stays on. All seems normal. At a light, I turned off the car, and then restarted, code disappears, when i try to flash it via the short out, 93, ODB1, only code 12, which is normal. Turn on car, no SES, drive for a min, then turns on. If the car sits long, the longer it takes for the code to come on, it seems.
Once i did flash, and it came up with Code 6, or something ending 6. So, What can it be?
Old Mar 14, 2003 | 11:55 PM
There are two codes ending in 6 that have to do with the opti. Others are EVAP, refrigerant pressure and Pass-Key.
Count the flashes better next time.
Old Mar 15, 2003 | 12:32 PM
Aeromaks's Avatar
Ok, Codes came up today, 21, and 26.
Anyone know what those mean?
Thanks.
Old Mar 15, 2003 | 01:08 PM
Xride's Avatar
21 - TPS circuit
27 - EGR vacuum control solenoid circuit
hope that helps
Old Mar 15, 2003 | 01:25 PM
Thanks.
DTC-21 = TPS sensor circuit, voltage high
DTC-26 = Quad driver circuit #1.
The "Quad driver" is always a mystery to me on the 93's... they used a seperate "driver" for the high current loads (solenoids) in the 93's, and then incorporated the drivers into the PCM on the 94 and ups. If you assume there is a one-to-one correlation of the 93 codes to the 94/95 codes, DTC 26 would correspond to the EEC canister purge solenoid. But I am not sure if there is such a one-to-one correlation.
warmeck
Feb 5, 2015 11:04 AM
Gtpguy
Jan 26, 2015 04:50 PM
NewsBot
Jan 8, 2015 11:29 PM
Z28Wilson
Aug 1, 2002 04:27 PM
z28projects4ever
9
Jul 16, 2002 07:48 PM
