all people with the twin intercooler ATI
Old Mar 14, 2003 | 08:13 PM
mehoffz24's Avatar
im not sure how much of this is true but, i was told that the plumbing is a huge hassle, and not woth it. i dont want to think that beause i know alot of the high horse power cars are runnin them, i need the ground clearence and need cool air. i just want to go 6# t/i all bolt ons. i think that the person that said that obviously didnt know what they were talkin about.
Old Mar 14, 2003 | 09:09 PM
SMOKNZ's Avatar
It is a hassle, but not a huge one. It really isn't that hard to do. Some tips for putting it together that I have found is to warm up the rubber parts using a hair dryer or a bullet heater (its winter here still) and that makes the rubber really pliable and it will aid in putting everything where it needs to go. If you don't wanna go that route you can use a little motor oil on the inside of the rubber parts. It allows everything to slide around during assembly and will eventually get absorbed by the rubber so it won't cause anything to come loose later. I have used both methods with sucess. It takes a little time to get it all placed right, but its far from impossible.
Bill
Old Mar 15, 2003 | 01:34 AM
ramair96ws6's Avatar
I had never even put headers on a car before i installed my blower and just about everything else on it.... well i cant take all the credit my wife was a big help but i set up the intercooler in my bedroom to see how everything would go together before i even tried to install it and it helped out alot. and knowing i wont have to upgrade so is a nice thing to know also the ground clearence alone is well worth the effort oh yea the extra power from the nice and cool inlet temps is a nice touch also
if you want some pics of the intercooler setup let me know i have pics of it all setup in my room and what it looks like in the car
Steve
Old Mar 15, 2003 | 10:03 AM
Arctic_White_WS6's Avatar
I'm just going through this process right now. I had to buy some extra rubber hose for the connection between the two metal pipes between the passenger intercooler and the blower. The rubber connector they supplied was not long enough to connect the two pipes.
Also, for the air intake to the blower, I had to cut the rubber 90 down and also cut the rubber hose between the 90 and the air filter in order to place the air filter in a position that didn't hit the other intercooler hoses.
The position of the bypass valve connection on the rubber 90 for the blower intake was also in a position that it was up against the blower outlet tube. It took some tight squeezing to get that to fit!
So yes, some modifications were required, and it was a bit of a PITA, but I would do it all over again if given the choice. I like the fact that they do not reduce ground clearance. I know I won't be damaging expensive intercoolers.
It was no where near as hard as getting my headers to fit!
Brent M.
Old Mar 15, 2003 | 02:57 PM
mehoffz24's Avatar
thanks for all the replies. that helps alot. 96ws6 would you mind sending some pics. i would like to see them. im definately goin to get the p1sc t/i, all you have are bolt ons with stock programing and make that much power. i have 100k with bolt ons. i plan on going through lonnie pavits and having it pullied down to 6psi to be safe. if i get the btm, and gauges i shouldnt have any issuses right? when you guys get them tuned your goin to the dyno with lt1 edit?. these are just a few questions i have before i purchase this and clear out my bank account
thanks again
Old Mar 15, 2003 | 02:59 PM
mehoffz24's Avatar
oh yea and the lt4 clutch set up is fine to handle 400 horse right. im running nittos and commin off the line at 3000,
1995 white t/a m6 100k, running strong
Old Mar 19, 2003 | 05:39 PM
mehoffz24's Avatar
ramair96 could you please send me a pic, that would be greatly appreciated. mehoffz24@aol.com, sorry if im buggin you, just gettin ansy
Old Mar 20, 2003 | 08:29 PM
sorry about that havent checked the forums in a little bit but i will send you the pics
Sorry about that
Steve
Old Mar 24, 2003 | 12:19 AM
Mr.Whitey's Avatar
I'd like some pictures also please if you don't mind.
taformula93@aol.com
Old Mar 25, 2003 | 02:25 PM
athens96ta's Avatar
May i have pics too?
lathens@***.net
RX Speed Works
Oct 1, 2015 10:19 PM
Beave2780
Sep 23, 2015 12:37 PM
94ZinEdgewater
Sep 8, 2015 09:55 PM
GusarskiSS
Exhaust System
Sep 2, 2015 03:51 PM
