383 stroker guys...?Questions?
Old Mar 14, 2003 | 07:16 PM
Supermanx500's Avatar
I blew my motor 2 days ago. Slung Con. Rod.....wen through the coolant housing and block....
I want to build a new motor from the block up.....
I was think that I would go with a 383 stroker. I can get a block used for like 300 and get the cyl. bored out. I can get a kit for like 1700 with the pistons rods rings crank.
What other cost am I going to have?
I heard something about getting the crank case bored?
Can I use the stock cam and rockers?----(Will be raplaced 2 months after)
I have P&P heads and headers.....
How much to Bore?
What other parts do I need?
Old Mar 14, 2003 | 08:25 PM
gb95zconv's Avatar
To deckthe block is like $100
To bore .30 0ver is $100
to line hone journels $125
Clean and flux block $75
install cam bearings $30
freeze plugs $20
so thats $400-$500 for machine work
Balance rotating assembly $200...your kit should be prebalanced
Old Mar 14, 2003 | 09:03 PM
CAn The stock Topend handle the bottom end 383 stroker for a moth or 2 till I can build it up?
Where can I get the best kit for under 1800$....I want to be able to spray nitrous.......
What kinda of shot would I be able to spray with this set up?
Old Mar 14, 2003 | 09:25 PM
Max 93's Avatar
it can handle it just fine, you just will not be making much more power than before. How big of a shot do you want to run? My crank rods and pistons cost me $1000. It has forged rods and pistons with a cast crank. It will be able to take a nitrous just fine.(my kit only goes up to a 175 shot)
Old Mar 14, 2003 | 10:11 PM
What type of power gains have you seen in your setup? Times and dynos? if you have them.
Where did you get your set up?
Old Mar 14, 2003 | 10:26 PM
Max 93's Avatar
mine isn't done yet. It's just a short block on a stand. But I plan to have it in the car in a month or two.
Old Mar 15, 2003 | 09:16 AM
gb95zconv's Avatar
The top end will handle it fine...you just want get the full hp gains that a 383 will give you without better flowing heads. Youll want hardened push rods.
I went with SRP forged pistons....$450
Eagle H beams rods.....$500
Eagle forged crank......$600
Balancing.....$200
I also am having standard 4bolt main caps put in for $150
That setup will handle the 200 shot that I want to run with ease.
I plan on making 400hp NA with ported heads and the cc305 cam....this is a small cam for this setup but I need to pass emmisions so its as big as I can go.
Other cost.....gasket set...$190 from Thunder Preformance
Old Mar 15, 2003 | 10:30 AM
Will Mac TruFit Headers and Y Pipe w/ 3'Cut out Flow Goo enough for a 383 stroker?
Old Mar 15, 2003 | 02:14 PM
Max 93's Avatar
It all depends on the heads and cam you plan on running. I personally would get something with a 1 3/4 primary.
D1SC383LT4
Jan 1, 2016 01:56 PM
D1SC383LT4
Jan 26, 2015 01:41 PM
Killer94z
Jan 13, 2015 12:06 PM
spearous
Jan 12, 2015 11:03 AM
