Need help...with grayish smoke
Old Mar 14, 2003 | 07:16 PM
BonesBrig5's Avatar
Today when I was driving around and flooring the car my friend noticed that whenever I was at WOT there would be this grayish smoke coming out of the exhaust. This was right when I floored the car, it quickly disappeared after I held the gas for a while...do you guys have any suggestions on what could it be? I did some research on this board and some people were saying this could be a lean mixture....
Old Mar 14, 2003 | 07:39 PM
frmula1's Avatar
From: Somewhere between a shotgun barrel, and a blood spatter on the wall.
gray smoke sounds like white smoke to me... burning coolant... head gasket/ cracked head
Old Mar 14, 2003 | 08:08 PM
Ben383's Avatar
Are you sure it was not more of a blackish smoke ? Reason I ask is at WOT you can be running rich causing you to burn fuel which cause blackish smoke .
Old Mar 14, 2003 | 11:57 PM
BonesBrig5's Avatar
head gasket
Wouldn't I be losing coolant if it would be the head gasket? My coolant level has been the same for over a month and this has been happying over a month also. Also with the head gasket wouldn't I be losing power?
Old Mar 15, 2003 | 12:36 AM
z28Power's Avatar
I don't think head gasket. Maybe it's just runnin' rich on gas. it coulda just been black, but since there wasn't much there it looked grey.
Old Mar 15, 2003 | 02:57 AM
BonesBrig5's Avatar
What could be the reasons for the car to be running rich?
Old Mar 15, 2003 | 09:28 AM
Loadre's Avatar
Mine runs rich, too. Still on the stock PCM, though. Does exactly what you said on WOT, gray-ish black-ish smoke out the back. Doesn't bother me, that just means i've got a little more power in there with a better tune
Old Mar 15, 2003 | 10:03 AM
Silver's Avatar
Mine does that too. Runs fine though. Doesn't last long. The longer I go without flooring it, the more smoke comes out. I'm thinking it's just carbon and stuff building up in the cat and then blowing out under heavy throttle. I run a little rich. My car is stock.
I mean think about it. If it only does it for a short time then doesn't do it anymore it's got to be buildup.
greenzee28
Sep 25, 2015 04:29 PM
jackpawt883
Sep 10, 2015 08:53 PM
blaze309
Sep 8, 2015 05:27 PM
86z28original
3rd Gen / L98 Engine Tech
Aug 20, 2015 12:20 PM
alphaauto
Jul 26, 2015 04:40 PM
