hardened or chromemoly ???
Old Mar 14, 2003 | 03:40 AM
bowtiepwr's Avatar
Question hardened or chromemoly ???
>which type of push rods are stronger ? hardened or chromemoly
Old Mar 14, 2003 | 04:05 AM
stik6shift98's Avatar
chromemoly
Old Mar 14, 2003 | 06:45 AM
BAD 97 WS-6's Avatar
I second that
Old Mar 15, 2003 | 01:58 AM
bowtiepwr's Avatar
>I guess that will be my decision then chromemoly it is .
Old Mar 15, 2003 | 03:37 AM
chesee48's Avatar
Chromemoly for sure
Old Mar 15, 2003 | 09:02 AM
OldSStroker's Avatar
Here's a cross-reference:
http://web.camaross.com/forums/showt...threadid=93709
Hardened chrome-moly (4130) is somewhat stronger than hardened low carbon (1015-1026) steel, but it's difficult to tell them apart unless they have manufacturer's part number or other ID on them. Both are stronger than non-hardened steel pushrods of course.
Old Mar 15, 2003 | 02:02 PM
Mad Machinist's Avatar
The alloy only tells part of the story, hard-drawn seamless chromoly (SAE 4130/4140) tubing for instance, can range anywhere from 125,000 psi tensile, to 275,000 psi. The heat treat process is the key.
Pushrods being an eccentrically loaded column due to angularity load and arc motion, are often strongest when in a configuration other than straight-tube. The key is putting the greater diameter/mass where it is needed most.
My .02
Gooday,
Mike
Old Mar 15, 2003 | 03:09 PM
Smoke T/A's Avatar
FWIW Chromemoly push rods are way over kill for sub 6000 rpms and stock valve springs pressures. I would only use them if you are running a cam that requires a lot of open seat pressure and 6800+ RPM. I would just stick to a stock replacement hardend push rod. But that's just my .02$
Joe
Quickss96
Jan 29, 2016 05:56 PM
football4life
Oct 4, 2015 07:48 AM
karpetcm
Sep 15, 2015 11:07 AM
sleeperZ96BT
Sep 9, 2015 08:28 AM
karpetcm
Aug 14, 2015 03:02 PM
