Thumping or clunking sound from rear!!Please help.
Old Mar 14, 2003 | 03:06 AM
OutlawLS!'s Avatar
Everytime I floor it from a dead stop I hear this thumping or clunking sound that I have noticed comes from the rear of the car. Right after launch it goes away. I am hoping it is something with the suspension. It only happens when I floor from a dead stop. Sometimes a little from a 20 roll. Other than that the car runs fine. What could it be?
Old Mar 14, 2003 | 01:05 PM
OutlawLS!'s Avatar
Anybody ever heard of any of this?
Old Mar 14, 2003 | 01:28 PM
ShaneS's Avatar
dunno man, could be a lot of things...
wheel hop?
loose bolt on lca?
loose bolt on phr?
loose shock mount?
:dunno:?
shane
Old Mar 14, 2003 | 02:55 PM
95 Z/28 LT1's Avatar
Super Moderator
Did you check your tranny mount?
Sounds like a tranny mount to me.
Old Mar 14, 2003 | 02:58 PM
Larnach's Avatar
Could be springs too, they clunk and pop everytime I go over a speed bump or hit the brakes real hard.
Old Mar 14, 2003 | 03:39 PM
ZZed's Avatar
The slight clunk at 20 is normal for an A4. Slop in the drive train. A clunk from a stop when floored it not exactly normal. Could be the tranny mount. A loose or damaged torque arm would cause wheel hop. I've had the bushings pop, but only when turning and when the car was new. It could also be excessive tranny slop. The first place I would go to is the tranny mount.
Old Mar 14, 2003 | 03:43 PM
99SilverSS's Avatar
When replacing my lower control arms they clunked until I torqued them to spec, much harder than thay needed to be IMO, but the cluncking went away. If its LCA's the clunking will also happen when turning or going over bumbs.
Old Mar 14, 2003 | 04:37 PM
OutlawLS!'s Avatar
Thumbs up
Thanks for your posts, I will look into what you all said.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
ModdedNerd
Dec 18, 2014 10:52 PM
squarehead
Nov 21, 2014 08:02 PM
FiNSTa
Jul 20, 2002 10:57 PM
