more OBD II trouble codes
Old Mar 14, 2003 | 02:23 AM
blown383's Avatar
I finally slapped the car back together and took it out for a drive. Now I have a VERY pronounced stumble around 1800rpm...its like when a person trips over a telephone wire and continues on their way. Its like that in any gear...I'm going to recheck the #8 spark plug wire because thats the only one that I took off.
I tried using some RTV around the header gasket where the last bolt broke on the passenger side exhaust manifold. Well...I guess its doing okay becuase there is a slight ticking noise. While driving around I got a SES light and it turns out to be a P0100 code again! Which is insufficient MAF activity. What would cause this to happen? My stock MAF brought up the same code before I borrowed a friend's Granatelli MAF. That MAF ran good for about a 3-4 weeks now. So what gives?
-B
Old Mar 14, 2003 | 08:26 PM
blown383's Avatar
ttt
Old Mar 30, 2003 | 06:37 PM
(Ken) 96 K1500S's Avatar
Re: more OBD II trouble codes
-B
Had the same problem in my truck with a GMAF if you are running a K&N air filter you will need to clean the sensor wires on the MAF as they get coated with the K&N oil...I have to do mine every few months...I use denatured alk and a q-tip...after that you will need to reset the ecm with a battery disconnect.
Ken
armedtrigger
Feb 24, 2015 08:30 PM
David Dorris
Jan 17, 2015 08:10 PM
Timberwolf
Aug 18, 2002 07:39 PM
91Bird305
Aug 5, 2002 01:39 PM
LT1
Jul 2, 2002 08:27 PM
