TB bypass
Old Mar 13, 2003 | 11:03 PM
Lunarson's Avatar
TB bypass
Has anyone else just clamped the rubber inlet hose directly to the hardline that runs along the pass. side of the intake. I just noticed this was possible a couple of weeks ago while changing my waterpump "again". I had originally had the hose clamped to a small metal pipe under the TB.
Old Mar 13, 2003 | 11:32 PM
smokindastangs's Avatar
i did.
Old Mar 13, 2003 | 11:58 PM
Achilles97's Avatar
Me too. There's no sense in buying or making a kit to join the two ends when you can just put them directly together....
Old Mar 14, 2003 | 12:03 AM
Smokn '94 Z's Avatar
Thumbs up Re: TB bypass
Can you show me a pic? I never really looked into that.
Old Mar 14, 2003 | 12:20 AM
Re: Re: TB bypass
You can only do that on a 1995-1997. Pre 1995 are different and you must use a connector to join the hoses.
Old Mar 14, 2003 | 12:35 AM
Re: Re: Re: TB bypass
Thanks again.... You are the man.
BTW. Can you tell me if I will win the lottery any time soon or should I not waste the $$$ for awhile....
Old Mar 14, 2003 | 01:30 AM
cals400ex's Avatar
yep, this is how you do it on your 95. just put two 3/8 inch vacuum caps on the TB holes and bleed the lines and your ready to go.
Old Mar 14, 2003 | 08:24 AM
Re: Re: Re: Re: TB bypass
You will not win the lottery...especially if you don't buy a ticket.
Old Mar 14, 2003 | 08:56 AM
Joe K. 96 Zeee!!'s Avatar
This post gets the 96Zeeee!!! TTT award!!!
I'll be using that pic this weekend.
68camaroboltz
Oct 5, 2015 01:46 PM
colts0455
Oct 4, 2015 09:47 PM
football4life
Oct 4, 2015 07:48 AM
Rod Bender
25
Sep 16, 2015 01:47 PM
colts0455
Sep 2, 2015 12:41 PM
