Two questions about optis
Old Mar 13, 2003 | 09:32 PM
Evilfrog's Avatar
Ok, i just finished changing my opti, and i have two questions.
First, when i took off the opti. I noticed a small ring around the bit that sticks into the engine.(very techincal, huh?) It doesn't look like a watertight seal. And it doesn't look like it holds anything in place. I was just wondering, what does it do?(i mean, i know the gm guys put it there for a reason.)
And i've been having battery problems, so im pretty sure the battery is dead. We put it on a charger, let it set for a few minutes. And tried to start it. It is making a wierd noise when the key is in the on position. Kinda like the beeping when the key is in the ignition, only grainy. And the speedo jumps up to 20mphs,. In the past, when the battery died, i just beeped weakly, or nothing at all. Any clues.
Old Mar 13, 2003 | 09:39 PM
DirtyDan's Avatar
Are you using a vented or unvented opti? Mine had a bad/deep ring worn into the spline shaft where the seal ran on it but I will be darned if I can find one though.
And your battery is toast, I've seen that many times before. It's like a weak "key in the ignition" ding because it isn't getting enough power. If you have a volt meter put it on the battery and check the voltage when you try to start it, it shouldn't be below 11 volts usually. 10 and below I would say a bad cell in it.
Dan
Old Mar 13, 2003 | 09:42 PM
Josh-'04 GTO's Avatar
Keep trying to fire up your car with a bad battery and the starter will be next on your "to do" list.
Old Mar 13, 2003 | 09:44 PM
Evilfrog's Avatar
I figured that it was the battery, i had to charge it for two days to get it to over here.(we did the work at my cousins house.) So its called a deep ring huh? What does it do? I mean, it looks like it would be a water seal, cept it doesn't look water tight. Its a non-vented opti.
Old Mar 13, 2003 | 09:48 PM
Evilfrog's Avatar
Not really trying to fire it. I just put the key in. There isn't enough juice in the car for me to trigger my cut off.(i have to hold a pad to the sensor i order for power to go to the starter) I just never heard the car my a grainy beeping noise before.
Sergio
Jan 27, 2016 04:27 PM
IgorT.455/406
Mar 12, 2015 03:39 AM
grgguy
17
Feb 23, 2015 07:57 PM
Injuneer
Dec 15, 2014 09:36 AM
pologreen97z
Dec 2, 2014 10:42 AM
