? about removing the EGR system.
Old Mar 13, 2003 | 08:46 PM
ur2slow's Avatar
Question ? about removing the EGR system.
I am in the process of finishing up my cam and header install. I have already blocked of the egr tube on the passenger side of the intake and re-installed the intake. Is it absolutly necessary to remove the egr valve also or just un-hook the vacuum lines going to it.
Also in the process of removeing the intake I destroyed the egr vacuum Solenoid. I have since purchased a new one (at $25) but am wondering now if I need it and can just return it to the dealership.
If I don't need these things anymore what do you do with the sensors, Leave them plugged in or un plug them and tape the ends off.
I will be taking the car to the dyno to have it tuned and eliminate the egr and air with LT1 edit, so that is not a problem.
I will be finishing tomorrow so any help would be greatly appreciated.
Jon
Old Mar 14, 2003 | 06:01 AM
ur2slow's Avatar
Anyone??
Ok, I guess the question I need answered most is do I need to have the EGR vacuum solenoid plugged in or can I eliminate it if I am programming out the EGR system?
Old Mar 14, 2003 | 06:15 AM
anaik's Avatar
If you're going to program it out, you can take everything off and cap the vacuum fitting on the intake.
I thought LT4s didn't come with the EGR function.
Old Mar 14, 2003 | 06:20 AM
ur2slow's Avatar
I'm glad that is the case. I will return that solenoid then. I beleive the corvette LT4 dont have EGR but my car still falls under the emission restrictions of an F-body and it has everything the f-body LT1 has.
It makes it a real PITA to get parts from the dealership because I have to always cross reference everything between a 96 corvette LT4 and a 97 LT1 to make sure I am getting the right thing.
timmy39120
May 8, 2015 11:41 AM
97SSdude
Dec 31, 2014 07:43 PM
thenewkid
Nov 18, 2014 12:57 PM
Jul 4, 2005 05:00 PM
1994TransAm
Aug 31, 2002 09:33 PM
