Street Twin.....will a stock master cylinder work?
Generally the stock master cylinder/clutch actuator combo does not provide enough travel to fully disengage the ST. The result is hard shifting, especially getting the car into first or reverse from a dead stop. Mine was that way.
Rich Krause
Rich Krause
Mine worked fine with the stock master, once I put the sleeve kit on the slave. Without the sleeve kit, there was not enough movement to fully disengage. Neither the person I bought the used Street Twin from nor myself had any problem with the sleeved slave, but the guy I eventually sold the setup to said the slave started leaking after he installed it.....
oldschool
Feb 9, 2016 09:21 PM
