What Are Some Good Upgrades for LT1's That Can Be Had From LS1 Cars?
Old Mar 13, 2003 | 02:31 PM
95 Z/28 LT1's Avatar
Super Moderator
There are a lot of cosmetic stuff people have done, like front clips and consoles, but I am talking about stuff that is a performance upgrade.
Things like the LS1 to LT1 front brake swap, or the LS1 driveshaft. What are some other things that you guys have swapped onto your cars to increase performance?
I want to try to swap in a LS1 plastic gas tank, but i am sort of hoping someone else will try it first so I don't have to be the guinea pig on that one.
Old Mar 13, 2003 | 03:29 PM
GREGG 97Z's Avatar
LS1 engine? That would be a nice performance upgrade
Old Mar 13, 2003 | 03:53 PM
Super Moderator
LOL, yeah, the engine would be a good mod.
What about the radiator? Would that be any better, or would it even work?
Are the electric fans any different, or would those be any better than LT1 fans?
Old Mar 13, 2003 | 04:09 PM
GREGG 97Z's Avatar
I've not heard that they use a different fan or radiator but they might. My car runs plenty cool though with the lower stat, csi and fan programming, I don't think a different radiator would make any difference. Actually I just added the CSI and it still runs the same temp, it stays just a hair above 160.
Old Mar 14, 2003 | 02:02 AM
cals400ex's Avatar
i can't think of any other off the top of my head. however, i was told the aluminum drive shaft gave an extra 10 horsepower. i don't know how accurate that is though.
Old Mar 14, 2003 | 02:51 AM
treyZ28's Avatar
From: looking for a flow bench so Brook and I can race
selling the LS1 block can guy some nice upgrades
more seriously-
rear brakes have a "better" design. how much or if they can interchange is beyond me.
sway bars and suspension?
Old Mar 14, 2003 | 03:20 AM
Severous01's Avatar
for the rear brakes, you will need the entire axle. they have a dofferent offset(?) and will rub on the axle if not changed
Old Mar 14, 2003 | 05:07 AM
stik6shift98's Avatar
front brakes rotors calipers and all....
Old Mar 16, 2003 | 05:39 AM
Pinchy's Avatar
An idea
The LS1 camaro's rack and pinion setup is a 16:1 ratio, and the LT1 is a 14.5:1 or maybe 14:1 I'm not for sure but I know it's close to that. Anyways, for quicker steering response than what you have now, you could just switch out the units. I was told by a guy who works at a junkyard that F-body guys were buying the newer versions for replacing the older ones but improving somewhat at the same time.
Old Mar 16, 2003 | 07:42 AM
Anderson's Avatar
You can get the coils off the LS1, and do that $700 opti mod.
Old Mar 16, 2003 | 07:50 AM
Re: An idea
Have not heard that about the ratios. I have heard people say that the angle where the intermediate shaft bolts up to the rack was a little different.
Old Mar 16, 2003 | 09:56 AM
Super Moderator
I never thought thought of the replacing the steering rack.
Anyone here actually done this?
Old Apr 8, 2003 | 04:25 PM
1993formula's Avatar
Re: An idea
not to knock anyone, but 14:1 is a quicker ratio than 16:1, just FYI.
I'm just digging around cause I need a new rack, but I have found no indication of people "upgrading" to a quicker ratio. Mine is about 2 1/4 turns of the steering wheel lock-to-lock, which translates to, IMO, some pretty quick steering already.
Much better than my stock Jeep, which was 20:1, which came out to 4 1/2 turns lock-to-lock. Cornering was like driving a tractor. that I upgraded to a variable box(from 17:1 in the middle to 14:1 on the edges), much nicer at about 3 1/2 turns lock-to-lock.
-keith
GhostZ28
Dec 7, 2014 11:53 PM
USAirman93
Nov 24, 2014 03:37 PM
ChrisFrez
Nov 23, 2014 10:33 AM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
Jul 4, 2005 05:00 PM
