Mixing oil
Old Mar 13, 2003 | 09:54 AM
treyZ28's Avatar
From: looking for a flow bench so Brook and I can race
Red face Mixing oil
stupid question yes-
but my buddy here at school who really knows his **** (9 sec all motor nova anyone )says that he never has because he has heard they will actually repel each other.
old wives tale or truth we have no clue, couldn't find anything on mobil1.com
now were just trying to find something somewhere to put this myth down
9/10 outa hes right and makes me feel like a dumb *** so i just said "i'll look into it" rather than "sure you can"
Old Mar 13, 2003 | 10:19 AM
Gripenfelter's Avatar
Why would you mix oils???
Old Mar 13, 2003 | 02:37 PM
treyZ28's Avatar
last time i changed my oil i had 2 10-30s and grabbed 3 5-15's on accident. didn't really care, it was like 8* out
Old Mar 13, 2003 | 03:54 PM
Black bow tie's Avatar
I wouldn't worry about it, as far as I know (and read) syth's have no problem blending with dino oils. If you really need the last word on oils...go here:
www.bobistheoilguy.com
Old Mar 13, 2003 | 03:58 PM
Buttercup's Avatar
As long as the bottles are marked with the SAE "starburst" for automotive oil use you should be able to mix and match any weight, brand, type of oil without problem.
Old Mar 13, 2003 | 04:05 PM
Z28SORR's Avatar
Yes it's OK! All you do is loose the properties that make the syn. cost more, thereby wasting money. They do not repel each other.
Old Mar 13, 2003 | 04:25 PM
hairbear21's Avatar
You can mix brands and types, but NEVER EVER mix viscoties. It will work for a while, but you are causing serious harm to the internal components by using different viscosities. The viscoties are made to reach different levels at operating temps. If you have two different types, ie, 10w30 and 15w40, one starts out as 10 weight (the w is actually for "winter"), and the other starts out as 15 weight. Once at operating temp, one is a 30 weight, and the other is a 40 weight. Just by comparison, you can tell that you have two different weights of oil actually fighting against each other.
Old Mar 13, 2003 | 04:28 PM
hairbear21's Avatar
Another bit of advise is that if you ever buy a car from anyone and they freely mention that they run different viscosities of oils, I hope that you are buying that car with the sole purpose to rebuild it.
Old Mar 13, 2003 | 04:38 PM
joeSS97's Avatar
Mixing different viscosities will do no harm.Say you mix a 5w 40 and a 10w 40,what you have is 7.5w 40.Also.I am pretty sure the W stands for weight.
Old Mar 13, 2003 | 04:54 PM
How did you come to the notion that mixing oils has any negative effect? Personal testing experience or hearsay? I have spent a fair amount of time on the before mentioned oil site and have read nothing that supports your statements.
Old Mar 13, 2003 | 05:33 PM
treyZ28's Avatar
they were both syntec
pimpen1024
Aug 19, 2015 08:36 PM
Noct
Jul 14, 2015 01:18 AM
jl1ne
Jul 7, 2015 08:38 PM
streetbad
Advanced Tech
Jul 5, 2015 10:40 PM
SergheiS
Jul 5, 2015 03:27 AM
