Blew Head Gasket! Help?!
Old Mar 12, 2003 | 11:03 PM
Supermanx500's Avatar
I think that when I blew it, I bent a valve sence water doesn't compress all that well..............but what else could this hurt engine wise????????????????
Old Mar 13, 2003 | 05:29 AM
badass383's Avatar
Do you mean a conn rod? Valves don't compress anything. A valve only sees high pressure when it's seated so the stem wouldn't get bent.
If head gas. problem, you could have water in the oil, oil in the water or leaking air into both. You could have water in the cylinder. Have you tested it for a bad gasket? (leak down or coolant system pressure test)? Are you loosing coolant?
Just wondering
Old Mar 13, 2003 | 10:36 AM
Ihave rad. Fluid in my oil and Rad. Fluid coming from the pass. side head area..........So its a connecting rod?
Old Mar 13, 2003 | 10:50 AM
grygst76's Avatar
blown head gasket, if you blew a connecting rod you wouldnt be able to keep the motor running and you would hear loud knocking noises, but you said you bent a valve? you probobly have a hole in your piston now. Better take the head off and check before you run it again!! How do you know you bent a valve?
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
Jazsun
Dec 29, 2014 12:14 PM
Donwest22
Parts Wanted
Dec 18, 2014 11:10 AM
