Buy ls1 with heavy mods and76k?
Old Mar 12, 2003 | 10:11 PM
96WS6T.A.roadracer's Avatar
Question Buy ls1 with heavy mods and76k?
I work @ a dealer where we took a 98 z with long tube headers, MAF, NOS, Air box, rev limiter, hurst shifter, and other suspension goodies. It runs excellent but idles rough and has some valvetrain tick at idle. Could aftermarket rockers and springs cause this or do ls1 valves need adjusting? I know this motor has been run hard. I've also heard of early ls1's oil problems. I have a 96 ws6 that is tired @128000. I know I could be trading one prob for another. How do ls1's hold up with mods? This one runs like a scalded dog but the NOS and Valvetrain scare me.
Old Mar 12, 2003 | 10:33 PM
stik6shift98's Avatar
trade it.....
maybe its just the notorious ls1 piston slap
Old Mar 12, 2003 | 10:42 PM
Yeah, I really want to trade BAD I just don't know what a modified ls1 is supposed to sound like at idle.
Old Mar 12, 2003 | 10:49 PM
dontyu have other ls1 u can listen to....u work at the dealer
Old Mar 12, 2003 | 11:04 PM
A dodge dealer! Got a friend who is a mechanic who has a 00 ws6 but his is stock and whisper queit compared to the z. Does anyone have ls1's with cams-bigger valves-springs that cause noise. do ls1 valves need occasional adjusting like lt1's? Valvetrain noise is what scares me most. Guess i could pull covers!
Old Mar 12, 2003 | 11:30 PM
SSDude's Avatar
The noise of the engine might depend of what cam it was modded with. If the car is modded with a cam that has an LSA below 114, it might lope like a ***** and crack your teeth. Some modded LS1s sound like sewing machines. There is absolutely nothing wrong with them. Good luck and I hope that you find a car that you enjoy.
Old Mar 13, 2003 | 07:25 AM
My84Z's Avatar
look up the last owners name and call him and talk to him i am sure he wouldn't mind telling you and tell him be honest if he beat it cause you are really thinking about buying it.
Old Mar 13, 2003 | 08:56 AM
PhantomTA's Avatar
Moderator
LS1's have a none adjustable valvetrain.
You should be able to tell if the car has a cam or is just running rough. Unless you have no expirence with modded cars
Old Mar 13, 2003 | 09:37 AM
Camaro00_ss's Avatar
SSDude, check you sig length, it's longer than some posts!!
Old Mar 13, 2003 | 10:26 AM
2002 NBM Bird's Avatar
Its probably the cam that is making those noises. If its real choppy and sounds almost like a nascar it probably has a big nasty cam in it
Old Mar 13, 2003 | 12:27 PM
99SilverSS's Avatar
Well you know one thing if the motor has been run hard and its still running hard then it will handle your fears. As for the drivetrain noise thats due to the cam. LS1's are noisy motors with all kind of tics and knock sounds, even when they are new. With injectors and the motors general nosie most LS1's sound like they need a good valve lashing, but when they get opened up you find out they are just fine.
Old Mar 13, 2003 | 09:43 PM
stik6shift00's Avatar
yeah i have 112 LSA....but i like it
Old Mar 13, 2003 | 09:49 PM
My84Z's Avatar
Just in case you missed this you work at the dealership should be easy to get an address and phone number just talk to the guy and i am sure he will tell ya
Old Mar 13, 2003 | 09:56 PM
95GRNZ's Avatar
Thumbs down
I wouldn't touch that car even with a long stick.
TS
Old Mar 14, 2003 | 03:25 AM
chesee48's Avatar
car with mods= beat on
