Are changing the spark plugs worth it?
Old Mar 12, 2003 | 08:51 PM
BlazeOne's Avatar
Just curious. Is it worth swithcing out the plugs for NGK TR-55's? Can you really notice the difference or have you had some problems? Thanks for the response!
Old Mar 12, 2003 | 11:22 PM
fbird95's Avatar
The only plugs i have had problems with were the bosche platinum +4 or whatever they are. They sucked and i went back to the stock plugs cause after a week the car started backfiring and hesitating real bad. I had two sets of them. The wires were bad too. I recomend nobody use these ever.
Old Mar 13, 2003 | 04:02 PM
UnbelievabLS1's Avatar
Can't go wrong with NGK's.
They're all I've ran in all of my f-bodies.
Old Mar 13, 2003 | 05:51 PM
35thanniv.SS's Avatar
The NGK's are great. Never use platinum plugs.. they are too hot.
Old Mar 13, 2003 | 07:36 PM
Camarocks's Avatar
Are the LS1 Fbody plugs the same as LS1 Vette plugs? I should change mine when I get home next week.
Old Mar 13, 2003 | 07:47 PM
96SFLZ's Avatar
Yeah, the Vette and F-body plugs are the same.
Blaze, I doubt you'll notice any difference by switching to NGKs (or any other plug) unless you have quite a few miles on the plugs that are in there now (factory I assume). If you are going to change plugs though, NGKs are the way to go, IMO.
Old Mar 13, 2003 | 08:33 PM
stik6shift98's Avatar
i wouldnt change plugs until you get nitrous....or get quite a few miles on it
Old Mar 13, 2003 | 08:39 PM
TransAmLS1's Avatar
EXACT same motor. So yes, they will work.
Old Mar 13, 2003 | 11:30 PM
BlazeOne's Avatar
Thanks for the info!
Old Mar 14, 2003 | 09:41 AM
petegz28's Avatar
I just had AC Delco Rapid Fires put in mine. At least I think that is what they are called. I have 51,000 on my LS1 and I could tell a small difference in throttle response. But I also put on Taylor plug wires as well.
Dark Zeiro
Mar 11, 2015 07:15 AM
jasonduaine
Mar 7, 2015 09:44 AM
94Z28LS1toLT1
Feb 28, 2015 08:33 PM
Dan_the_ManZ28
Feb 21, 2015 02:01 PM
Jazsun
Dec 29, 2014 12:14 PM
