rear end+tranny
Old Mar 12, 2003 | 07:57 PM
Seanbardol's Avatar
rear end+tranny
hey can anyone tell me if my 94 3.4 liter v6 has the same rear end as the z28 of that year with 3.42 gears just without posi, also was the t5 borg warner 5 speed offered in z28's of that year too? all replies appreciated , thanks
Old Mar 13, 2003 | 08:22 AM
JC93Z's Avatar
I am not 100% sure on the rear end but I think they are the same from a V6 to a V8 just without posi.
The manual tranny offered in the Z-28's form 93 on are the T-56 6 speeds. The 5 speeds wouldn't last behind the LT-1 or LS-1 motors.
Old Mar 13, 2003 | 01:22 PM
MustangEater82's Avatar
all 3.4Ls came with drim brakes and 3.23s, open differential... and manual trannies were T5s.
T5 is kinda weak never put behind anything more pwoerful then a 305 tpi 3rd gen.
Z28s come with varous gears and all have lsd, and 4 wheel disc brakes.
They do bolt up the same way, and all connectors fit up the same, they are both GM 10 bolt rear ends. If the z28 is still around you can check the gear codes in the glove vompartmetn or on the driverside door.
Gu6 = 3.42s
GU5= 3.23s
GU4= 3.082
I think Gu3= 2.73s
96SilverRam
Nov 20, 2016 11:19 AM
HarleyZ28
Oct 5, 2015 06:23 AM
BLK1997Z28
May 1, 2015 12:23 PM
thenewkid
Apr 12, 2015 07:42 PM
