TCI Convertor Part number help
Old Mar 12, 2003 | 05:23 PM
GreekZ's Avatar
i need the part number for the TCI Street Fighter torque convertor with 2800 stall. i called summit and they didnt seem to know which one it was and i need to order this fast.
thanks guys
Old Mar 12, 2003 | 09:58 PM
ramermanz28's Avatar
part #
Here you go TCI-243105. Cost is $436.95 plus shipping. Converter works great. Installed in my car about a month ago and I love it. One thing though, your factory torque converter bolts wont work. You'll have to use 7/16th inch bolts, same size bolts that hold your flex plate to the crank. Also you'll have to drill the flex plate holes to accomodate the 7/16th inch bolts, but not too much. If you want to upgrade your flex plate be sure to get a 153 tooth or you can get a 168 tooth, but you'll have to change your starter to one that works with a 168 tooth flex plate. If you go with the 168 tooth you will also have to modify your dust cover to clear it because it is larger in diameter than the 153 tooth. It all sounds complicated but its not. Good luck, if you have any questions about the install of this converter let me know, Rob.
parkers Z28
Mar 11, 2016 08:14 PM
FirebirdGT
Dec 13, 2014 10:25 PM
Brandon Wittmer
Dec 7, 2014 12:15 PM
