Oil Changing
Old Mar 12, 2003 | 05:07 PM
stevenscamaross's Avatar
Exclamation Oil Changing
Using Mobile 1 synthetic, how often should I be changing my oil.. the guys at the dealership.. say Mobile 1 synthetic will last 6,000 miles.. my 3,000 is up... What do you guys think?
Steven
Old Mar 12, 2003 | 05:10 PM
stik6shift98's Avatar
change it i change mine every 2800
Old Mar 12, 2003 | 07:16 PM
Z28x's Avatar
I change mine every 4,000
I think it can go 7,500 but since oil isn't that expensive I like to changing it sooner.
I personally wouldn't change it any later than 5,000
Old Mar 12, 2003 | 08:19 PM
redz28kn3007's Avatar
I change mine every 3-4000 miles and I use "half synthetic", mostly Castrol. The Mobil synthetic lubricates better,no doubt, especially when starting the cold engine, however it doesn't mean you can leave it in forever... when it's dirty it's dirty and needs to be changed... remember the good old days when they built the 427 high compression engines ....did they even sell synthetic oils back in the early 70s ???
Old Mar 12, 2003 | 09:49 PM
Gossco95's Avatar
What do u guys use..... a fully synthetic or a synthetic blend?
i changing over from convential to synthetic ... and a lil' confused on what I should be using.
Old Mar 13, 2003 | 01:36 AM
Dr EviL's Avatar
I change mine every 3000. Makes the car "healthier"
Derrick
Old Mar 13, 2003 | 01:50 AM
GrdLockV6's Avatar
I change my Mobil 1 every 3,000 miles. Screw the dealer, I wouldn't go longer then 4,000 without changing it... well, I PERSONALLY wouldn't go longer then 3,000, but as a suggestion i wouldn't tell you anything longer then 4,000
BTW, don't skimp on fluid changesand other maintenance things with your car. If you drag race the car often, or drive it hard, or hell even under regular driving, your car will appreciate it in the long run (by not dying on you that is). Oil changes a thousand miles or two earlier then you'd really like are a small price to pay for the benefits in the long run.
Old Mar 13, 2003 | 02:57 AM
dmnall's Avatar
I change my oil with conventional (carquest brand by Valvoline) every 3000 miles... Actually if you are driving the mostly on Freeway/Highway and hardly do any city driving then you can stretch oil changes to every 5000 miles and still be safe.. Since it depends if my oil is a little dirty but not that bad I will go over 3000 miles but if it is dark brown almost black, I change it no matter if it has 100 miles or even 1000 miles... As a general rule every 3K but if I am driving like 65 Miles a day one way to work then every 5K won't hurt either..
Old Mar 13, 2003 | 06:58 AM
SFB767's Avatar
Dr EviL-
Are you from Colorado and did you ever have a friend by the name of Chris P. who moved to Florida around '95?
The reason why I ask is because your e-mail looks VERY familiar, I know I've seen it on a forward before.
Old Mar 13, 2003 | 07:00 AM
SFB767's Avatar
I change mine right before 2,500 miles. There's a lot of construction going on in central FL and it probably makes the oil dirtier.
Old Mar 13, 2003 | 01:18 PM
Dr EviL's Avatar
Originally posted by SFB767
Dr EviL-
Nope, sorry. I've lived In California all my life.
Derrick
Old Mar 13, 2003 | 03:04 PM
MRZ28HO's Avatar
Thumbs up
Originally posted by redz28kn3007
... however it doesn't mean you can leave it in forever... when it's dirty it's dirty and needs to be changed...
That is the sole reason for oil changes, not mileage. I change mine every 3,000 miles (or every three weeks) because the oil starts getting black and contaminated.
Old Mar 18, 2003 | 11:29 PM
johnnymg's Avatar
That's way too conservative. Syn oil should be good for 10K miles (assuming you're driving a lot).
I change the oil every 5K miles. I've got almost 300K miles on my 88 IROC with the original motor. The motor uses 1 quart of oil every 2.5K miles.
JohnG
Old Mar 18, 2003 | 11:57 PM
99blackSS's Avatar
My 3,000 miles are up and I changed the oil today. I use Mobil 1. I am sure you could easily go 5k even with fossil oil you can go 5k.
Old Mar 19, 2003 | 10:12 AM
Camarocks's Avatar
I put Valvoline in the Camaro and Mobil One in the Vette since it came with that from the factory. I've always changed the Camaro's oil at 3k miles and plan on doing that with the C5 also. Oil is too cheap to not replace when you're supposed to.
