Pacific Alaska, California, Hawaii, Oregon and Washington
great gas mileage
Old Mar 12, 2003 | 02:40 PM
kal2k's Avatar
great gas mileage
260kms in the SS and still half tank, not bad at all and also have had this tank in the car for 3 weeks now i should be able to go till this weekend in it, love the ls1 Mileage
Old Mar 12, 2003 | 02:44 PM
TopSpeedZ28's Avatar
My 97 Z with LT1 does about 300k on a tank pretty regularily. I do notice that I can get 200k+ on the first half tank and then less than 100k on the last half. I guess (pretty obviously) that the top half is much bigger than the bottom half. I was wondering if it is the same for the newer LS1's??
Old Mar 12, 2003 | 03:30 PM
Zedzag's Avatar
Once you hit halfway you better keep you eye on the gas gage! I once thought that I would get 500kms to a tank when I had 250kms and half left. Boy was I wrong.
Old Mar 12, 2003 | 04:00 PM
kal2k's Avatar
ya i have heard that the top is heavy, how ever alll u gotta do is keep the foot outta her a lil and it wont be so bad i am aiming for 430iish i should be able to get it
Old Mar 12, 2003 | 04:56 PM
todd15's Avatar
what gear do you guys cruise in? say going between 60 and 70?
Old Mar 12, 2003 | 05:01 PM
bunker's Avatar
max I got out of my Trans AM when it was stock in city driving was 450kms to a tank after programming.
Old Mar 12, 2003 | 05:56 PM
mr_muff's Avatar
60 in 4th, 70 and up in 5th if im holding a constant speed, drop down to fourth if i wanna go a litle faster.
Old Mar 12, 2003 | 06:44 PM
sleeperZragtop's Avatar
Our tanks are V-shaped....the first have is ok, but after that your done
Old Mar 12, 2003 | 07:48 PM
kal2k's Avatar
65ish and above 5th and anything below that ill be in 4th
Old Mar 12, 2003 | 08:37 PM
Tw!tchb!tch's Avatar
20 $ doesnt even get me half a tank and its gone in three days of just driving 10 - 12 min to and from work , not even 20 km each way. . . but Im usually mashing the gas atleast a couple times there and back
28.5 # injectors
Old Mar 13, 2003 | 04:30 AM
bunker's Avatar
Injector size will not affect your gas milage at all aslong as the PCM/ECM knows that you have that size injectors in there, it should be able to hold a constant A/F ratio without any trouble.
Old Mar 13, 2003 | 11:24 AM
Draco's Avatar
Yep, I am running 50lb injectors and neither my idle quality nor my mileage changed after the upgrade.
Old Mar 13, 2003 | 11:53 AM
Camaro ChriSS's Avatar
That doesn't sound like a good story...
Yeah, our gas gauges are definitely not 'consistent' between when they are in the top half compared to the bottom half.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
MustangEater82
19
Sep 3, 2002 02:09 PM
simple
Aug 11, 2002 11:56 AM
